Steerpike
Aug 06, 2015Aspirant
RN104 failed disk - how to activate replacement disk
I have an RN104 with 4x2TB drives in X-Raid configuration. 1 drive has been reported as failed, and device is reporting 'Degraded' (but still working). I ordered identical replacement 2TB drive a...
- Aug 06, 2015
If it is doing a resync it will tell you on the volume tab.
Do you have a backup?
It does not sound like it is doing a resync.
If it isn't I would:
1.Upgrade your firmware to 6.2.5
2. If after this update the disk is still inactive, then hot remove it, wait about 10-15 seconds then hot insert it.
vandermerwe
Aug 06, 2015Master
- SteerpikeAug 06, 2015Aspirant
I'm reluctant to upgrade as I spent months finding a stable release, but I guess I could go with 6.2.5.
I don't have a backup as this device 'is' my backup; I can recopy all the files, if necessary, from the primary NAS (so yes, I guess that means I have a backup) - it's just in a remote location so will have to be moved.
Is there nothing I can do remotely to try to 'kick off' the resync? I'm 1,000 miles away from the NAS at the moment though I could talk someone through the process.
- vandermerweAug 06, 2015Master
Have you tried a simple reboot, possibly more than one to see if this gets the resync going?
If it doesn't then you'll need to remove and reinsert the disk.
It is possibe to do this remotely but again you would need to put the unit into tech support mode and get someone from Netgear to fix it. It is simpler to just remove and reinsert the drive which hopefully will be all that is required.
- SteerpikeAug 08, 2015Aspirant
I finally had someone on site today. I had them hot-remove the drive. While removed, I monitored the UI. Soon after the removal, the UI restarted/reconnected - and upon reconnect, I saw (on the 'volume') page, 'balancing in progress. 50% completed'. I waited maybe 60 seconds or more, no change. I had my guy insert the drive. No change for several minutes, but then I saw the 'progress' on the 'balancing' bar go from 50% to 51%. Now, an hour later or so, it's at 54% - so 'something' is happening.
I have a 'balance' job set for every Tuesday and Saturday at 10:30am. it normally takes~1hr to complete. It hasn't even started since the drive entered degraded mode, but for reasons I can't explain, log shows it started this morning (sat) at 10:30am ... this I cannot explain. Also, in the logs, I see entries from just now for the removal and re-add - "Disk: Disk Model:WDC WD20EFRX-68EUZN0 Serial:WD-WCC4M1AAXEFL has been added to Channel '2' of the head unit.". There was no similar corresponding entires in the log for when I did the first hot-add of the new drive last Thursday.
So I can't explain why the balance this morning kicked off but the balance last Tue, and last Sat, did not (while degraded). It's almost like it no longer saw itself as degraded today? I guess I'll let the balance complete, and then see if a rebuild of some sort is indicated.
To be clear - what exactly am I looking for - a 'rebuild' or a 'resync', or something else?
Thanks
