AKLGUY
Aug 26, 2021Apprentice
RN316 Drive upgrade
Hey community. I had recently sn Experiance which appeared that there was a failed drive upgrade on my RN316 which had 3x 8TB and 3TB 3TB I replaced the bay 4 which was a 3TB with an 8TB and for som...
- Aug 26, 2021
AKLGUY wrote:
Thank you StephenB I will give that a go this weekend.
If it is the 3TB in bay 5 that is bad I guess I can put in the 3TB i took out of Bay 4 right? Just format it first?I suggested testing the old Bay 4 drive first on your other thread, just to make sure it is healthy. If you run the write zeros test, you will not need to format it.
Aug 26, 2021Guru - Experienced User
AKLGUY
You’re helping in the other older thread which I though had issues so created a new one let’s this one close
