fearlesss
Sep 29, 2015Aspirant
Stuck on Installing FW X-raid2 Mode
So We've had a NAS RN104 for about 2 years now and have decided to upgrade to the RN204 and I can't for the life of me get this thing to work. It's brand new out of the box for a week. I've got 4 x...
- Sep 29, 2015
Which firmware is this running? You may wish to update the firmware if the unit is running old firmware.
You may also wish to have a look at the compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641
mdgm-ntgr
Sep 29, 2015NETGEAR Employee Retired
You may wish to open a support case. Sounds like this will need some remote diagnosis.
fearlesss
HI mdgm
I've decided to pull out all the SSD's and put in a 2.5" Hard Drive and it seems to have tempoarily fixed the problem. It has completed the boot process and I can login, Now I'm just going through the process of installing 3 of the SSD's and then removing the HD to replace with the 4th SSD.
Fingers crossed it will all work.
I will jump onto support if this doesnt work though cheers .
- mdgm-ntgrSep 29, 2015NETGEAR Employee Retired
You may also wish to have a look at the compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641- fearlesssSep 29, 2015Aspirant
It;s got 6.3.5 Firmware on it which is the latest I think. I upgraded it as soon as I could log into it.
I have checked that list, however it doesn't have any Samsung SSD's on it at all.
I can only assume they just haven't tested any Samsung drives yet, because these are not cheap drives at $350 each
