stevey198321
Nov 01, 2015Aspirant
Updating owncloud
Hi, i am trying to update owncloud on my Netgear ReadyNAS 314 and when i update (from within owncloud admin page) i get the error "Please upload the ca-bundle.crt file into the 'config' directory" ...
- Nov 22, 2015
Right, i got mine working and this is how for anyone who does a search for this error
On the following link right click and press save as, change it from txt to all files and rename it ca-bundle.crt then save
https://raw.githubusercontent.com/owncloud/core/stable8.1/config/ca-bundle.crt
go into your readynas, make sure you have selected to view hidden files
then go to data/.apps/owncloud/web/config/
copy the ca-bundle.crt file into this folder
go back into the website of your owncloud
it should now update
hope this helps
stevey198321
Nov 18, 2015Aspirant
Thanks Jasper, i still haven't fixed mine, to be honest i haven't had time to play around with it. But thanks for the pointers you have given
stevey198321
Nov 22, 2015Aspirant
hope this helps
