snafas
Dec 30, 2012Aspirant
Re-use of a disc formally used in a Duo v1
I have replaced a 1TB drive in my ReadyNAS Duo v1 with a new 3TB drive. Now I want to use my 1TB drive as an external USB hard drive. I have put it in an external cabinet and connected it to both my M...
JimCH1
If you are using Windows 7, find Disk Management from the Control Panel:
Control Panel\System and Security\Administrative Tools\Computer Management
Then choose Disk Management from the menu on the left hand side.
You should then be able to see your disk and reformat it.
