galaxgreta's avatar
galaxgreta
Volume Expansion question
Hi, I have a Readynas 3200 with OS 6.9.5 HF1 and up until some days ago I have 12 2Tb discs using X-RAID2 with a total of 18,15 TB. I now installed 2 new 6TB discs and though that after rebuild wou...
  • Sandshark's avatar
    Sandshark
    Mar 29, 2025
    I think StephenB got the math wrong and the volume will expand by 8TB (assuming you've got the standard RAID6).  Still, since only bays 1-3 can handle a disk >2TB on a 3200, you might want to consider higher capacity drives.  But you will need 4, so you'd have to figure out what to do with the the 6TBs you already bought.
ProSupport for Business
