voidness
Mar 05, 2017Guide
Ready Nas - Lost Volume after forced reboot
Hi Support,
My 104 crashed and not responding so I unplugged and restarted, now the existing volume is gone, the error on is "remove inactive volumes to use the disk, 1,2,3,4"
are you able to help me restore the lost volumes ?
Thanks,
Dinh
- mdgm-ntgrNETGEAR Employee Retired
This is the community, support is at netgear.com/support.
You can send in your logs if you like (see the Sending Logs link in my sig) but you'll likely need to contact support (there would be some costs involved). - jak0lantashMentorThe Boot Menu is certainly not hidden, there is even KB articles about it. And if you do some research, you'll find info about Tech Support Mode. BJT this is for people who are proficient in Linux and know about mdadm and BTRFS.
- voidnessGuide
Just to update everyone who might run across this thread with the same issue.
So I didn't want to pay support and was willing to lose all my data, because my HDDs has lots of ATA errors so I chucked them into the freezer (in airtight bags of course), I left it there for a few weeks, (because I had to buy a backup disk big enough to backup my data, hence the few weeks wait)
once I got my backup disk I put the drives back into the NAS and proceed to remove inactive volume and create new volume, and to my surprise the old volume came back intact with everything on it (I think all I did was click remove inactive then click new volume and the old one just came back, it didnt even asked me to put in a new volume name just restored itself). I am not sure if the fridge help or this error is merely a bug on the front end.
I also did try to run these commands, but it didnt seems to help
mdadm --examine --scan
mdadm --assemble --scan (with really force )so yea I didnt lose my data and I now have a backup
I'm glad it all worked out, and thx for updating the thread with the outcome.
- jak0lantashMentorMaybe you want to upvote this "idea": https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Change-the-incredibly-confusing-error-message-quot-remove/idi-p/1271658
