voidness
Mar 05, 2017Guide
Ready Nas - Lost Volume after forced reboot
Hi Support, My 104 crashed and not responding so I unplugged and restarted, now the existing volume is gone, the error on is "remove inactive volumes to use the disk, 1,2,3,4" are you able to...
voidness
Mar 05, 2017Guide
Thanks, do you know if there is anything I could try ?
Sandshark
Mar 05, 2017Sensei
I have noted a marked increase in posts about this type of problem since the release of OS 6.6.0. I think somebody at Netgear needs to look into why that is. The system should be more robust than this.
- F_L_Mar 13, 2017Tutor
I got this myself tonight. Ultra 4 running 6.6.1.
Did you ever find a solution how to retreive the volume?
