TrelixG
Aug 08, 2021Aspirant
Ready NAS 104 data dead
Hallo to everyone, I have since 3 years the readynas 104 with: 1st bay nas drive 3TB 2nd bay nas drive 3TB 3rd bay nas drive 4TB 4th bay nas drive 4TB. Before five days i got alarm, that ...
TrelixG
Sep 10, 2021Aspirant
Hello to everyone,
firstly thank you a lot for your help.
I managed to recover all my data as follows:
I cloned disk 2 with DiskGenious.
I connected all 4 disks to PC, then used "reclaime Freeraid recovery" and then "reclaime File Recovery".
I bucked up all my Data.
I have following question.
I placed all four disks again to my readynass 104 in the correct order.
Now I have a healthy system but still no access to the data of the disks. No Volume.
Is there a way to reconstruct the previous volume or the only way to use the NAS drive is to create a new volume?
Thanks
Sep 10, 2021Guru - Experienced User
I'm glad you got your data back. I suggest putting a backup plan in place for your NAS.
TrelixG wrote:Is there a way to reconstruct the previous volume or the only way to use the NAS drive is to create a new volume?
I don't think there is a way to reconstruct it, given the info in your first post. So I think you'll need to create a new one.
I suggest running the disk test from the volume settings wheel (waiting for it to complete) before you restore your data.
