Saram
Apr 12, 2021Aspirant
Ready NAs 104: issues with VPN (PIA)
Good afternoon, I've using a VPN (PIA) for about 2 years and a ReadyNAS 104 longer. After PIA updated its software several months ago, I could not connect ReadyNAS with the network. The onyl ...
Sandshark
Apr 13, 2021Sensei
See https://openvpn.net/community-resources/how-to/#scope to expand your VPN to other local devices. Installing OpenVPN on the NAS is another option if you want the NAS to be able to access the internet via the VPN.
Saram
Apr 13, 2021Aspirant
Thank you for your assistance.
I need only local connectivity without having to use the workaround (disconnect, reconnect VPN).
I have Plex server in my PC (the only PC with VPN) and when I lose connectivity with my ReadyNAS, my local network devices and PCs lose access to the NAS as well.
I use PIA (Private Internet Acess)
- Protocol is set to openVPN as apposed to WireGuard (tried both)
- PIA is set to allow LAN traffic
- My ReadyNAS IP is also set to bypass the VPN.
Thank you again for your suggestion. I will read the OpenVPN article.
