storageuser
May 10, 2021Aspirant
Ready NAS 104 not responding
My readynas 104 with version 6.10.4 is not responsive. I was transfering some data and it suddenly became unresponsive. I rebooted. It powered up normally. I can see it from my computer where it ...
Sandshark
May 10, 2021Sensei
It sounds like you may have a full OS partition. If you have SSH enabled, the NAS is still accessible via SSH, and are familiar enough with the Linux command line, you may be able to fix it yourself with some guidance, or at least confirm that's the problem. Alternately, you may need to go in via support mode Telnet, which is a bit more involved. You can try to boot in read only mode via the boot menu and see if you can get to the log page and see if it says you have a (nearly) full OS partition. I don't recommend you immediatyely try to download the full log .zip, as that'll eat up more OS partition space.
If any of that scares you, then paid support from Netgear is likely your best route.
- storageuserMay 10, 2021Aspirant
Thank you. I am trying your suggestions.
Well I got access back. Honestly, I connected to it and found nothing useful. The logs are clean. I just kept rebooting it and it eventually returned. Almost like I am dealing with a windows box.
Now everything is normal. Makes me lose all confidence in this thing. Maybe it is cooked and I need to replace. Yuck. Are the new versions good?
