Embersoffury
Mar 27, 2015Aspirant
Ready NAS 104 System Offline
hi people, I have recently been experiencing some issues with my Netgear ReadyNAS 104 storage array. Everytime it boots up, it works fine front-view display works fine and i'm able to access it...
mdgm-ntgr
Apr 07, 2015NETGEAR Employee Retired
How big is the media library you want to use with ReadyDLNA.
The NAS appears to keep on needing to generate a new ReadyDLNA database.
- nhelpAug 20, 2015Aspirant
I have this similiar issue everytime I install and attempt to use Plex. This has occurred 5 times, and the only resolution is to start from scratch, with a clean install and not to use plex. Any assistance would be greatly appreciated.
- StephenBAug 20, 2015Guru - Experienced User
I've sometimes seen issues when plex is updating the library. The NAS nic card starts rapidly blinking, and the NAS stops responding to ping. The only way to bring it back is to pull the plug.
Is that the symptoms you are seeing? Or something else?
If so, then perhaps start with a small library (using files that you know are properly tagged). Then gradually move more into it.
