doccy
Dec 01, 2018Aspirant
Ready nas 212 with cameras
I just want to link up a couple of cheap home surveilance cameras that would write to the nas when movemenbt is detected. Should be low usage.
The NAS only comes with 1 surveillance code and I u...
Dec 02, 2018Guru - Experienced User
Probably you need to find cameras that can write directly to network shares (perhaps with FTP).
Sandshark
Dec 03, 2018Sensei
Hopjng to not step on any toes suggesting a competing product, but I find Blue Iris running on even an older (Core2Duo or better) PC and using the NAS as a backup device for it to be hands-down better than anything that will run on an entry level NAS. Camera limit is well beyond what most PC's can handle without any additional charge, and the list of supported cameras is huge. Some of the newer mini PC's would likely work quite well with it, though I just used my most recently retired general purpose PC (a Core2Quad) and a KVM so i don't need a dedicated monitor, mouse, and keyboard. Google is your friend.
