PSXman
Oct 14, 2023Aspirant
Ready Nas 214 V6.10.9
I have a Readynas 214 and 104 which I think I have setup identically the 104 ive had for years and i just got the 214 recently. The issue im having is that the 214 doesn't appear in the windows n...
PSXman
Looked at that its the same model wdtv that I have what i dont understand is the protocols are the same between the 2 nas i have the smb+ addon and thats set the same as well i might just reset it and start again do you know if i can resotre the config from the 104 to the 214 ie accounts shares etc
PSXman
I have found the solution after a lot of head scratching there was a setting under smb protocol for legacy windows discovery both Nas are now shown on the network and are both available to the WDTV thanks very much for your help with this and advice
l
