Azad1994's avatar
Azad1994
Follower
Nov 23, 2025
Ready nas 3138
after repalce HDD showing Error. volume is inactive or dead valume is readonly
  • Did you replace one drive because it failed?  Are you sure you replaced the correct one?
  • StephenB's avatar
    Download the full log zip file from the logs page, and look there.  There's a lot more information.
    If you need help analyzing it, you can copy the full zip to cloud storage, and send me a private message (PM) with a download link.  Make sure the permissions are set so anyone with the link can download.  You can send a PM using the envelope icon in the upper right of the forum page.
    If you still have the disk you removed, then make sure you keep it intact.
    Do you have a backup of the data?
ProSupport for Business
