Amistar
Aug 01, 2016Aspirant
Ready NAS 314 USB Backup
Hello Community, i got a little/Big/Huge Problem. I'm saving Data from to of my Servers to a ReadyNAS 31400-100. So far so good. Shares are made and Backup's land on the RN. But when i hook a USB...
Amistar
Aug 04, 2016Aspirant
So i did all the Firware Updates and everything looks really good but one thing just dosen't seems to Work.
just for not Showing any Names i wiped out some Information. But as you can see the configuration is correct. Provider, Server and Port is filled out correctly.
Now to my Problem: Everytime i fill out the From part with [email protected] and press Sent Test and Apply it takes over the Adress from the User and lets the Password blank. Is that a bug or does it just change some Information?
Aug 04, 2016Guru - Experienced User
In my opinion the password blanking is a bug. Netgear might view it as a security feature - but in many scenarios the blank password is actually applied - and that makes it a bug for me.
Arguably setting "from" differently from "user" should just be deprecated, since that increasingly triggers spam filters and in some cases outright email rejection.
- mdgm-ntgrAug 08, 2016NETGEAR Employee Retired
We are aware of the issue with the blank password field, but it's not high on the priority list at the moment.
