valeroso
Aug 05, 2019Aspirant
READY NAS 3312 Filled with Snapshots
Hello, I have a ReadyNAS 3312 that shows snapshots are occupying almost half of the total space available. The confusing part is that I don't have snapshot enable on any of the shares. I have...
Aug 05, 2019Guru - Experienced User
About how old is the data volume? Do you recall what firmware was installed when you created it?
valeroso
The data is just over a year old. I can't remember what version of firmware but I believe it was a 6.x release.
- StephenBAug 05, 2019Guru - Experienced User
valeroso wrote:
The data is just over a year old. I can't remember what version of firmware but I believe it was a 6.x release.They all are 6.x. If the firmware was very old, there might have been a snapshot conversion step that failed. However, if the NAS is ~1 year old, then that isn't the issue.
- valerosoAug 06, 2019Aspirant
Thank you for your help so far.
Any ideas what else I can try?
- StephenBAug 06, 2019Guru - Experienced User
Check to see if btrfs sees the snapshots via ssh.
# btrfs subvolume list -s /data
Substitute your own volume name if you are using flexraid.
Perhaps post back with the list that you get.
