jacquesvanzijl's avatar
Sep 06, 2012
ready nas 4200 boot issue stop at 63% #19380277
Hi Guys
We have a customer's 4200 that doing go past 63% when you boot the device up, When we do a volume check skip i can get into the nas but see no shares or iSCSI partition
and if we click on volume settings my volume size look like this
Disk space
-518373623 MB (-2736%) of 18 TB used
Additional 10 GB reserved for snapshots
Please see logs below if you could think of something to repair the volume
Severity Date Message
Thu Sep 6 16:08:19 CAT 2012 System is up.
Thu Sep 6 13:53:26 CAT 2012 System is up.
Wed Aug 29 06:25:02 CAT 2012 Volume C is approaching capacity: 99% used 367G available
Mon Aug 27 01:52:04 CAT 2012 RAID scrubbing finished on volume C.
Sun Aug 26 20:00:17 CAT 2012 RAID scrubbing started on volume C.
Sun Aug 26 07:30:19 CAT 2012 The on-line filesystem consistency check detected problems with your data volume. Please reboot the system with the volume scan checkbox enabled to do a full filesystem consistency check and repair.
Sun Aug 26 00:00:02 CAT 2012 The on-line filesystem consistency check has started for Volume C.
Fri Aug 24 06:25:02 CAT 2012 Volume C is approaching capacity: 98% used 462G available
Tue Aug 21 14:22:47 CAT 2012 System is up.
Mon Aug 20 01:52:21 CAT 2012 RAID scrubbing finished on volume C.
Sun Aug 19 20:00:07 CAT 2012 RAID scrubbing started on volume C.
Sun Aug 19 00:15:07 CAT 2012 The on-line filesystem consistency check detected problems with your data volume. Please reboot the system with the volume scan checkbox enabled to do a full filesystem consistency check and repair.
Sun Aug 19 00:00:02 CAT 2012 The on-line filesystem consistency check has started for Volume C.
Sat Aug 18 06:25:02 CAT 2012 Volume C is approaching capacity: 97% used 740G available
Fri Aug 17 12:16:21 CAT 2012 System is up.
Fri Aug 17 06:25:07 CAT 2012 Volume C is approaching capacity: 97% used 739G available
Tue Aug 14 06:25:02 CAT 2012 Volume C is approaching capacity: 96% used 892G available
Mon Aug 13 01:51:40 CAT 2012 RAID scrubbing finished on volume C.
Sun Aug 12 20:00:55 CAT 2012 RAID scrubbing started on volume C.
Sun Aug 12 00:15:11 CAT 2012 The on-line filesystem consistency check completed without errors for Volume C.
Sun Aug 12 00:00:02 CAT 2012 The on-line filesystem consistency check has started for Volume C.
Mon Aug 6 01:50:30 CAT 2012 RAID scrubbing finished on volume C.
Sun Aug 5 20:00:24 CAT 2012 RAID scrubbing started on volume C.
Sun Aug 5 00:15:08 CAT 2012 The on-line filesystem consistency check completed without errors for Volume C.
Sun Aug 5 00:00:02 CAT 2012 The on-line filesystem consistency check has started for Volume C.
Fri Aug 3 21:51:21 CAT 2012 System is up.
ProSupport for Business
