Lukas_K
May 09, 2019Aspirant
Ready Nas Duo v1
Nas not responding after replacement a second dics.
Button and second disc diod is blinking.
i cant login into front panel.
I dont have acces to my share files.
i recived an email the disc is...
Lukas_K
- What firmware is running on the Duo? its up to date
- What disk (manufacturer/model) did you insert? wd20eurx-63t0fy0 2tb
- Raidar dont see nas
May 09, 2019Guru - Experienced User
Meaning 4.1.16?
Not a good sign. Is the PC connected over wifi? If you have a firewall running on the PC, try disabling it.
- Lukas_KMay 09, 2019Aspirant
Meaning 4.1.16? yes
Network is ok.
- StephenBMay 09, 2019Guru - Experienced User
The system should be visible to RAIDar.
If you've just inserted the disk, then perhaps wait for 3-4 hours. If it isn't visible at that point, you could try powering down the NAS and removing both disks (labeling by slot). Power up, and confirm that RAIDar discovers the NAS, and reports a no-disks status.
Then perhaps try testing the drives in a PC using vendor tools (seatools for seagate, lifeguard for western digital). You can attach the drives using either SATA or a USB adapter/dock.
