alanmusic
May 31, 2013Aspirant
ready nas duo v2 installation time
I needed to install a new drive in my readynas due to the disaster of losing both of my drives with all of my data on it. so, I recovered the data ($$$$) and have it on an external drive ready to inst...
Jun 04, 2013Guru - Experienced User
Then the instructions for a factory reset are on page 16 here: http://www.downloads.netgear.com/files/ ... 6Dec11.pdf
alanmusic wrote: yep, it is Duo v1
To perform an OS reinstall or factory reset:
1. Power off your system.
2. Using a straightened paper clip, press and hold the Reset button.
3. Press and release the Power button to power on the system.
4. To perform an OS reinstall, continue to hold the Reset button until all Disk LEDs flash once,
after about 5 seconds, and then release the button.
To perform a factory reset, continue to hold the Reset button until all Disk LEDs flash
twice (once at 5 seconds and then 25 seconds later), and then release the button.
There is a description of the LED patterns here: http://home.bott.ca/webserver/?p=324 Yours doesn't seem to fit though.
