alanmusic
May 31, 2013Aspirant
ready nas duo v2 installation time
I needed to install a new drive in my readynas due to the disaster of losing both of my drives with all of my data on it. so, I recovered the data ($$$$) and have it on an external drive ready to inst...
Jun 04, 2013Guru - Experienced User
I don't recall the total time. It runs a 5 minute disk test first, then there is a 10 minute window (if you don't want the default XRAID, you can select flexraid during that time). Then it formats the data partition. So 15 minutes is the minimum.
You should be able to see progress via the RAIDar app though.
