JanDandridge
Jul 31, 2016Aspirant
Ready NAS Duo won't reboot
We came into work this morning and our Ready Nas Duo was not working and won't detect on RAIDar. We have hit the Reset Button and turned it on, the Blue Light is flashing, LED lights flashed on and o...
- Jul 31, 2016
Yes, you will have to turn it off at the power if it is stuck during the boot process.
mdgm-ntgr
Jul 31, 2016NETGEAR Employee Retired
Is this the Duo v1 or v2?: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Do you see any of these LED patterns?: http://home.bott.ca/webserver/?p=324
JanDandridge
Thank you for getting back to us. We bought it in January 2010, so I'm assuming that means it will be V1. The fan has been making a high speed noise for quite sometime, it has just slowed and is less noisy. The blue light is now permanently on and the left LED light (1) is now on green, but nothing on (2). It is still not registering on RAIDar
