Schmobol
Mar 17, 2019Follower
Ready NAS RN 104 Anitvirus not updating
Hi,
I have a readyNAS RN104 with 6.9.5 firmware version (latest avaible) and since March 9th 2019, the antivirus is not updating anymore. Any idea what's going on knowing that my NAS has no iss...
Anonymous
Mar 18, 2019Hi Schmobol, you might be affected by the same issue discussed in this thread. Should that be the case, asimb's post might also help to solve your issue.
Kind regards
Anonymous
Mar 18, 2019Oops, sorry for the missing link.
- StephenBMar 18, 2019Guru - Experienced User
The RN104 no longer has enough memory to run everything. So Netgear is removing the AntiVirus service for the RN100 series in the 6.10 release (which I suspect will be released soon).
If you are running AV on your RN100 series, the straighforward solution to the AV update problems is to turn it off now.
