AmalW
Dec 06, 2020Aspirant
Ready NAS RNDP200U - Not Reading Disks
Dear All, In desperate need of some help! Setup: My ReadyNAS Model Name: RNDP200U (Model No: RND-2A) is not reading the two disks. Using Raidar 4.3.0. X-Raid2 Setup - I believe as I did no...
Dec 06, 2020Guru - Experienced User
AmalW wrote:
1. I have ordered a similar NAS off ebay; RND2000v2. If I plug the old drives in the new NAS, will it work? Or will it erase the data?
It will not work - the nas either won't boot, or it will erase the data.
If you do need to off-load the data, you can connect one of the disks to a Windows PC (via SATA or a USB adapter/dock), and use R-linux for Windows to access the files. https://www.r-studio.com/free-linux-recovery/
AmalW wrote:
there was a odd noise (cycling) as the disks tried to spin I assume.
It could be a disk failure (one which might be hanging the SATA backplane). I suggest powering down, and testing the disks in a Windows PC with Seatools (again, they can be connected either via SATA or a USB adapter/dock).
AmalW
Stephen,
Many thanks for you message.
Ok so if will be damage limitation to recover data. Disaster if I cannot!
Is Seatools from Seagate I presume? Do I do that first or the linux recovery?
Thanks again
Thanks again
- StephenBDec 06, 2020Guru - Experienced User
AmalW wrote:
Is Seatools from Seagate I presume?Yes. https://www.seagate.com/support/downloads/seatools/
AmalW wrote:
Do I do that first or the linux recovery?I'd run the quick Seatools test first (it normally only takes 1-2 minutes). Both drives should be mirrored, so if one passes, you should be able to recover from it.
Note you will need storage to copy the files onto (for instance a USB drive). R-linux doesn't repair anything, it just gives you access to the files.
- AmalWDec 06, 2020AspirantStephen,
Thanks; I am ordering internal and external Seagate 8TB drives now, so hopefully can recover from one of the disks via my pc.
Regards
Amal
