AmalW
Dec 06, 2020Aspirant
Ready NAS RNDP200U - Not Reading Disks
Dear All, In desperate need of some help! Setup: My ReadyNAS Model Name: RNDP200U (Model No: RND-2A) is not reading the two disks. Using Raidar 4.3.0. X-Raid2 Setup - I believe as I did no...
AmalW
Stephen,
Many thanks for you message.
Ok so if will be damage limitation to recover data. Disaster if I cannot!
Is Seatools from Seagate I presume? Do I do that first or the linux recovery?
Thanks again
Thanks again
Dec 06, 2020Guru - Experienced User
Yes. https://www.seagate.com/support/downloads/seatools/
I'd run the quick Seatools test first (it normally only takes 1-2 minutes). Both drives should be mirrored, so if one passes, you should be able to recover from it.
Note you will need storage to copy the files onto (for instance a USB drive). R-linux doesn't repair anything, it just gives you access to the files.
- AmalWDec 06, 2020AspirantStephen,
Thanks; I am ordering internal and external Seagate 8TB drives now, so hopefully can recover from one of the disks via my pc.
Regards
Amal
