AmalW
Dec 06, 2020Aspirant
Ready NAS RNDP200U - Not Reading Disks
Dear All, In desperate need of some help! Setup: My ReadyNAS Model Name: RNDP200U (Model No: RND-2A) is not reading the two disks. Using Raidar 4.3.0. X-Raid2 Setup - I believe as I did no...
Sandshark
Dec 07, 2020Sensei
AmalW wrote:
6. I have tried another spare disk in the NAS, but does not do anything with it! Not seen by Raidar
This is what I meant by you having no luck with a scratch drive. Just to verify that you installed just the spare drive, correct? If so, and the drive you used is known to be good, then this is an indication that the NAS chassis has a problem.
You asked if there was any repair shop, and I already answered that the possible causes are not repairable. Netgear has never provided NAS repair services except under warranty and has not provided schematics or parts for any third parties.
AmalW
Dec 07, 2020Aspirant
Sandshark/Stephen,
Thanks for your message. I thought if I put in another unrelated drive and it did not recogise it, it would format and start up. It did not.
I have made some progress though finally!
Disk1 - Tests
Disk Info ok.
Short Generic Test - 100% pass
Short Disk Self Test - 100%
It did make a few odd noises on start up but tests ok :)
Disk 2 - Waiting for Seatools! It is being a dog again! "USB: Scanning for supported drives. Please Wait..."
Disk2 seems to be spinning ok though; no noises!
8TB Backup USB drive arrived from Amazon!
