AmalW
Dec 06, 2020Aspirant
Ready NAS RNDP200U - Not Reading Disks
Dear All, In desperate need of some help! Setup: My ReadyNAS Model Name: RNDP200U (Model No: RND-2A) is not reading the two disks. Using Raidar 4.3.0. X-Raid2 Setup - I believe as I did no...
Dec 07, 2020Guru - Experienced User
Sandshark wrote:
AmalW wrote:
6. I have tried another spare disk in the NAS, but does not do anything with it! Not seen by Raidar
This is what I meant by you having no luck with a scratch drive. Just to verify that you installed just the spare drive, correct? If so, and the drive you used is known to be good, then this is an indication that the NAS chassis has a problem.
That depends on whether the disk was already formatted (unless a factory default was done via the boot menu). Though RAIDar should have seen a "corrupt root" in that case.
Anyway, I still think it is worth circling back to this after AmalW has the data off.
AmalW
Dec 07, 2020Aspirant
Still waiting for Seatools to startup to check DISK2!
Restarted and plugged & unplugged several times!!!
Stuck on;
"USB: Scanning for supported drives. Please wait..."
I would have thought that Seagate would have some decent software tools! Been using Seagate drives for 20+ years in PC's & Macs!
