Phaedsys
Dec 12, 2017Aspirant
ready nas ultra 6 Drive expansion with 6tb drives
Hi My Pioneer Pro 6 has been running fine with 6 * 2TB drives in however when I fitted 6 * 4TB WD Reds (on the approved list) it will not expand past 8TB in Raid 5. have firmware 4.2.15 I hav...
bedlam1
Dec 12, 2017Prodigy
Firmware 4.2.15 is very old, the current version is 4.2.31, you need to update and perhaps factory default
Hopefully others will help with your expansion issue
You could also consider upgrading the NAS to OS 6 firmware, search the forum on this
- PhaedsysDec 12, 2017Aspirant
looks like that is solving the problem.... :-)
Thanks
- PhaedsysDec 13, 2017Aspirant
the 4.2.31 firmware only partially worked. It seems to be able to see all 3726 GB of each disk when I look at the "Status->Health" but the volume (X-RAID2) is only 8324GB.... it won't expand past the size it was with 6*2TB disks. any suggestions?
- StephenBDec 13, 2017Guru - Experienced User
What process did you use? It should be something like:
- Update to 4.2.31
- power down
- install 6x6TB
- power up, using boot menu to do factory reset
Given where you are, you should probably try the factory default facility in Frontview (system->update, choose the "factory default" tab, then click "perform factory default").
