Bullfrog2
Sep 15, 2020Aspirant
ReadyData 5200 running OS 6.10.3 with Sys fan control on the motherboard.
Hi I know this is an unsupported configuration, thought I'd let others know my experiences of attempting to run OS6 on a ReadyData5200 unit. I followed some instructions online which bizarrely ...
Bullfrog2
Sep 16, 2020Aspirant
Hi
I've since settled for 40 degrees as my target temperature otherwise as soon as the machine ceases to idle the fans start ramping up. Essentially with the mode I've selected , the sensor connected to temp2 controls the three fans. The readynasd process still controls the CPU fan.
These datasheets/documents were my source of info on the fan/temp chip.
https://www.kernel.org/doc/Documentation/hwmon/w83627ehf
http://read.pudn.com/downloads649/doc/2643726/W83627DHG-Programming-Guide.pdf
https://www.nuvoton.com/resource-files/DA00-WW83627DHG-P.pdf
Bullfrog2
