sabahl
Jan 23, 2013Aspirant
ReadyDLNA patch for Sony Blu Ray Players
Hi, The latest batch of firmware updates from Sony for their Blu Ray players is not liking the format of the XML coming out of ReadyDLNA/miniDLNA. A patch has been created for miniDLNA which fixes...
Zaim
May 16, 2013Aspirant
kullyrai wrote: Hi Zaim,
Can you confirm the addon, and where I can get it from?
Is it also compatible with the ReadyNAS Duo v2?
Thanks
kullyrai
Hi, I got it from netgear support, not sure if it is going to be compatible with the duo v2, might be worth you contacting support and linking this thread.
