sabahl
Jan 23, 2013Aspirant
ReadyDLNA patch for Sony Blu Ray Players
Hi,
The latest batch of firmware updates from Sony for their Blu Ray players is not liking the format of the XML coming out of ReadyDLNA/miniDLNA. A patch has been created for miniDLNA which fixes the issue and is available from here.
http://www.bayofrum.net/~crees/patches/minidlna-fix-sony-bdp-sx90.diff
I have verified that this patch will fix the issue on a ReadyNAS NV+ but my low level techy skills are not very good and the re-MAKEd file is 950k versus the original 200k, and only works on the version of system that I own.
Would someone like to recompile miniDLNA as an Add-On/upgrade using the above patch to make the lives of Sony users happier until such a time as it can be folded into the main ReadyDLNA release?
- idimintuAspirantWould be dandy if there was a link for the Duo v1 :) Cheers in advance
