njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location etc... This did happen on my Duo as well, normally when adding new folders to the share which the DLNA server was using. However in the old option I was able to press a button that caused the files to be rescanned and that fixed the problem. Now I have the same problem with the NV+ V2 but the option to rescan the files is not present. I have tried using the slider control to turn the ReadyDLNA service off and back on again. Also I have tried rebooting the NV+ V2. Neither have worked unfortunately. Could anyone shed any light on this?
- ramiromagalhaesAspirantSo, here is my upnp-av.log As you can see, it scans a /c/Media folder, but there is no folder such as this one in my drive. In fact, I renamed it to c/public folder (it shows in my FrontView without the "/" before the "c/public"). Inside such folder, there are still c/public/Music, c/public/Pictures or my c/public/Videos. I must say that I did set c/public to be shared via ReadyDLNA service, and I assume it scans my subfolders.
[2012/01/18 18:16:19] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:16:19] minidlna.c:920: warn: Creating new database...
[2012/01/18 18:16:19] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:16:19] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:16:19] scanner.c:719: warn: Scanning /c/media
[2012/01/18 18:16:19] scanner.c:790: warn: Scanning /c/media finished (0 files)!
[2012/01/18 17:41:35] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 17:41:36] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 17:41:36] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 17:41:36] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 17:41:40] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 17:41:40] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 17:41:41] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 17:41:41] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:01:55] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:01:55] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:01:55] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:01:55] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:01:58] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:01:58] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:01:58] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:01:58] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:02:23] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:02:24] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:02:24] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:02:24] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:02:33] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:02:34] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:02:34] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:02:34] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:02:54] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:02:54] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:02:54] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:02:54] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 11:48:43] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:22:42] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:22:42] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:22:42] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:25:54] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:25:54] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:25:54] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:25:54] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:26:01] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:26:02] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:26:02] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:26:02] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:26:02] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:26:02] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:26:02] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:27:26] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:27:27] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:27:27] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:27:27] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:27:27] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:27:27] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:27:27] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:15] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:15] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:15] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:15] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:15] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:15] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:15] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:26] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:27] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:27] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:27] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:27] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:27] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:27] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:31] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:32] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:32] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:32] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:32] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:32] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:32] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:50] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:51] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:51] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:51] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:51] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:51] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:51] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:38:01] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:38:01] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:38:01] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:38:01] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:38:01] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:38:01] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:38:01] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:38:14] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:38:15] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:38:15] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:38:15] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:38:15] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:38:15] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:38:15] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/20 12:05:12] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/20 12:11:45] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/20 12:11:45] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/20 12:11:45] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/20 12:11:45] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/20 12:11:45] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/20 12:11:45] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/20 16:17:12] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/20 16:17:12] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/20 16:17:12] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/20 16:17:12] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/20 16:17:12] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/20 16:17:12] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/20 16:17:12] minidlna.c:997: warn: TiVo support is enabled.
If there is any other information I can provide to help solve this problem, please, let me know. - mdgm-ntgrNETGEAR Employee RetiredHave you tried turning ReadyDLNA off then on again? Is there a reason you needed to remain the /c/media folder? If you do you could try renaming it back, then disabling ReadyDLNA, then renaming it to public again and then re-enabling ReadyDLNA and see if that works.
- ramiromagalhaesAspirantI renamed my /c/media folder to /c/public because people here are used to using a "public" directory to share things.
I did a factory reset with the 5.3.3 BETA firmware, cleaning up my disks. Then, I created some users (I did not attach to no shares, but I thought that I should mention that). Then I copied some music into the /c/media folder and waited some time. I went to check on my LG TV and the song list updated ok. After that, I added pictures and a movie, and everything did show on my LG TV. Afterwards, I renamed the folder to /c/public and, although the files were listed, I could NOT view or listen to my media. So I stopped the ReadyDLNA service and restarted it. Again, all media was listed, but I couldn't view or listen to anything. At last, I tried to reboot my ReadyNAS, and I had the same problem again.
I made all that via the FrontView interface. Here is my upnp-av.log. It seems to me it shows the database was not updated.
[2012/01/22 16:01:12] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/22 16:01:12] minidlna.c:920: warn: Creating new database...
[2012/01/22 16:01:12] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/22 16:01:12] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/22 16:01:12] scanner.c:719: warn: Scanning /c/media
[2012/01/22 16:01:12] scanner.c:790: warn: Scanning /c/media finished (0 files)!
[2012/01/22 23:07:45] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/22 23:07:46] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/22 23:07:46] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/22 23:07:46] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/22 23:07:49] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/22 23:07:50] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/22 23:07:50] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/22 23:07:50] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/22 23:25:30] upnphttp.c:951: error: recv (state0): Connection reset by peer
[2012/01/22 19:52:20] upnphttp.c:951: error: recv (state0): Connection reset by peer
[2012/01/23 00:36:06] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 17:25:34] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 17:25:34] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 17:25:34] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:16:57] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:16:58] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:16:58] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:16:58] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:17:03] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:17:03] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:17:03] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:17:03] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:17:46] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:17:47] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:17:47] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:17:47] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:18:13] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:18:14] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:18:14] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:18:14] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:18:17] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:18:18] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:18:18] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:18:18] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:18:38] tagutils/tagutils-mp3.c:585: warn: File too small. Probably corrupted. [/c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3]
[2012/01/23 19:18:38] metadata.c:366: warn: Cannot extract tags from /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3!
[2012/01/23 19:18:38] scanner.c:498: warn: Unsuccessful getting details for /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3!
[2012/01/23 19:31:17] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:37:10] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:52:04] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:05] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:05] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:05] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:13] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:13] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:52:13] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:13] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:52:17] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:18] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:52:18] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:18] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:21] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:22] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:22] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:22] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:53:41] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:54:12] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3
[2012/01/23 19:54:25] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 02 - Shoot To Thrill.mp3
[2012/01/23 19:54:55] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:54:58] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3
[2012/01/23 19:55:27] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:55:27] upnphttp.c:1418: error: Error accessing /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 19:55:32] upnphttp.c:956: warn: HTTP Connection closed unexpectedly
[2012/01/23 19:55:34] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4283.JPG
[2012/01/23 19:55:35] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4284.JPG
[2012/01/23 19:55:37] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 19:58:22] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:58:23] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:58:23] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:58:23] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:58:27] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:58:28] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:58:28] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:58:28] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 20:00:50] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 20:01:05] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3
[2012/01/23 20:01:31] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 20:01:32] upnphttp.c:1418: error: Error accessing /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 20:01:37] upnphttp.c:956: warn: HTTP Connection closed unexpectedly
[2012/01/23 20:01:38] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4283.JPG
[2012/01/23 20:01:40] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4284.JPG
[2012/01/23 20:01:46] upnphttp.c:1418: error: Error accessing /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 20:01:51] upnphttp.c:956: warn: HTTP Connection closed unexpectedly
[2012/01/23 20:01:56] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 20:01:59] upnphttp.c:1808: error: Error opening /c/media/Videos/movie.avi
[2012/01/23 20:02:22] upnphttp.c:1808: error: Error opening /c/media/Videos/movie.avi
[2012/01/23 20:02:22] upnphttp.c:1808: error: Error opening /c/media/Videos/movie.avi - mdgm-ntgrNETGEAR Employee Retired5.3.3 has been posted. When you open the dashboard you should be prompted to update. Please update to that firmware.
- ripfaceAspirantHi All,
I was having similar problems with my Netgear Readynas Duo v2. Similar problem, no way to force a rescan of the media. To resolve the issues with NULL folders try deleting the folder.jpg in the affected directories. After this you will need to force minidlna to rescan as follows ....
1. Install the root ssh access add-on if not already done
2. Login as root (default password will be the admin password)
3. Find the minidlna process
$ps -eaf | grep minidlna
4. Kill the minidlna process with the following command
$kill -15 <process id>
5. Restart the minidlna process with the following comnad
$minidlna -R -f /etc/minidlna.conf
This will restart with the -R (Rescan) option which will rebuild the mysql database. It takes a good while, so be prepared for a wait if you have a large media collection.
If you still have problems, try killing the minidlna process and start it with the debug option .....
$minidlna -d -f /etc/minidlna.conf
Monitor the output for any errors ... or save the log to check it offline
$minidlna -d -f /etc/minidlna.conf | tee -a /tmp/minidlna.log
Hope this helps!
Cheers,
Ripface. - tbrosvikAspirantHi!
Probably a good tip by ripface, but I want an option where I don't have to use a commandline.
Netgear, please make ReadyDLNA able to rescan with a button in the Dashboard-solution!
Or maybe one of you supergeeks out there can make a add-on for NV+ V2. - mohareAspirantI am willing to try the kill and restart idea, but when I try to install the root ssh access add-on, I am told "Invalid update image" when trying to install EnableRootSSH_1.0.bin and "architecture is bad" when trying to install EnableRootSSH_1.0-x86.bin. I assume only one of them is right for the Duo v2, but since the first one didn't work I tried the other.
So, any ideas about how I can install the root ssh access add-on successfully? - ripfaceAspirantHi Mohare,
If any of the add-ons has "x86" at the end then they are only compatible with intel based devices. You want the EnableRootSSH that is for the ARM processor used by the ReadyNAS. You can find it here ...
http://www.readynas.com.nyud.net/downlo ... .0-arm.bin
Have fun!
Cheers,
Ripface. - mohareAspirantthanks. An additional question... looking at my upnp-av.log file, it appears miniDLNA is already stopping and restarting by itself.
[2012/02/12 10:44:23] minidlna.c:153: warn: received signal 15, good-bye
[2012/02/12 10:50:49] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
is this the same thing as running the kill/restart from the command line? - mdgm-ntgrNETGEAR Employee RetiredIs that when you rebooted the NAS? minidlna will be stopped when you reboot the NAS.
