njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location etc... This did happen on my Duo as well, normally when adding new folders to the share which the DLNA server was using. However in the old option I was able to press a button that caused the files to be rescanned and that fixed the problem. Now I have the same problem with the NV+ V2 but the option to rescan the files is not present. I have tried using the slider control to turn the ReadyDLNA service off and back on again. Also I have tried rebooting the NV+ V2. Neither have worked unfortunately. Could anyone shed any light on this?
- Bloggs_JAspirant
mdgm wrote: Try updating to ReadyDLNA 1.0.24: (link to http://www.readynas.com/forum/viewtopic.php?f=76&t=27946)
To install on the Dashboard, click Configure, go to the Add-ons tab, click the + button at the far right, browse for the location where you downloaded the add-on, upload the add-on etc.
After updating to 1.0.24 if that doesn't fix it this add-on will remove the ReadyDLNA database and thus force the ReadyDLNA database to be rebuilt on the new version: (link to http://rnasguide.com/wp-content/addons/arm/DLNAREBUILDDB_0.1-arm.bin)
I also have a ReadyNAS Duo v2 (as mentioned by ripface elsewhere in this thread) with pre-installed firmware 5.3.3 and had similar problems to that described in this discussion. In my case, I have been able to refresh the ReadyDLNA database successfully using the procedure described by mdgm.
Note that despite installing the ReadyDLNA_1.0.24.3 add-on, I still found that still the only way to refresh the ReadyDLNA database was to run the DLNAREBUILDDB_0.1 utility by adding the pseudo “add-on” DLNAREBUILDDB_0.1-arm.bin each time a refresh was needed.
That is the good news (although I agree with others that a "Refresh" database button is needed on the dashboard).
Unfortunately I then discovered some bad news as summarized by the table below.
Although this issue is arguably better directed at the minidlna project, it is disappointing that the table reveals some inappropriate and unnecessary transcoding. For example, the Samba Client section demonstrates that the ViewSonic VMP74 understands the original ".mp4" format but the DLNA/UPnP Client section indicates that it receives the streamed data from the ReadyDLNA server in a format that the VMP74 doesn't understand. Disappointingly, ReadyDLNA does not quite yet seem to match the DLNA server compatibility of the other NAS brand that I am currently using. - Live_1991Aspirant
punsterr wrote: No word yet...but the DLNAREBUILDDB_0.1-arm.bin workaround did the trick. Rebuilt the database and everything shows up just fine now. Hopefully our friends at Netgear will be kind enough to build a Rescan button into the GUI in the future. Please, oh please?!
Cheers i just run the DLNAREBUILDDB and now i can only see the top folder when i look at the NAS on the TV.
if i click on the Video folder there is nothing there :( sad face - mdgm-ntgrNETGEAR Employee RetiredNow that 5.3.5 beta is available there is no need to use the DLNAREBUILDDB add-on any more. Take a look at http://www.readynas.com/forum/viewtopic.php?f=148&t=62728
- Live_1991Aspirant
mdgm wrote: Now that 5.3.5 beta is available there is no need to use the DLNAREBUILDDB add-on any more. Take a look at http://www.readynas.com/forum/viewtopic.php?f=148&t=62728
Yep have install that.
still can only see the top folder when streaming to the TV, this sucks :( - Live_1991AspirantWell after rescanning and waiting one night there all back.
2 Questions?
On other program i was using before the NAS you could have a folder called " just added" where all the new stuff from the last 7 days would show up as a shortcut, can this be done on the NAS
Question
How come on the NAS a file is called Fringe - S01E03 - The Ghost Network but when i look for it on the TV its called The Ghost Network.
It only does this for some tv show and only some eps not all. ( drives me nuts as i have to look up which is the next ep ) - willy134ukAspirantstill no fix for this?or even a rescan button added,ive just tryed the latest beta and still getting null folders
- vicd1AspirantOn my old NAS you could specify that it rescans one time everyday and it also had a manual button to "refresh". Maybe this is something for the next update.....
- chirpaLuminaryThe 5.3.5-T41 beta should resolve this. It will rescan properly.
- vicd1AspirantI noticed that I can only see avi files on my Sharp TV and not any HD movies like mkv or mp4 files. Have anyone streamed HD movies through DLNA?
The TV is from 2012 and can play mkv files in a USB but through DLNA i can only see avi files - StephenBGuru - Experienced UserThe ReadyDLNA on the Pro will stream AVI, M2TS, MKV, MOV, MP4, MPG, TS, and WMV to my NTV550 in HD.
Though the UI is not the best.
