defcon84
Jun 20, 2018Guide
ReadyDR Error 255
I have a share with 422GB ReadyNAS 314 (v6.9.2) that i want to backup to a ReadyNAS 3312 (v6.9.3).
All goes well for 30 minutes, then i get:
"ReadyDR job failure: Unknown error 255 [Backup to NS5...
- Jun 26, 2018
Hi defcon84,
The 'Broken pipe' status indicates a network issue. Are both NAS devices connected on the same LAN? Are they connected to a switch or are they connected directly to the router?
JohnCM_S
Jun 20, 2018NETGEAR Employee Retired
Hi defcon84,
Can you download the system logs and provide it to us. You may check this link for the steps on how you can send it.
- defcon84Jun 21, 2018Guide
One NAS is online for 3 years and thus has many many logs.
Therefor I'm getting a timeout on the download logs (/dbbroker) page.
I can SSH into the NAS and get the files manually, which files do you need?
- StephenBJun 21, 2018Guru - Experienced User
The logs are rotated, so that shouldn't be giving you a timeout.
I suggest going in with ssh, and looking at the fullness of the OS partition next.
Another option is to use paid support (my.netgear.com), and give netgear remote access.
- defcon84Jun 22, 2018Guide
Is this what you need?
root@SKNAS02:/# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 4192192 660984 2862776 19% /
tmpfs 1015448 0 1015448 0% /dev/shm
tmpfs 1015448 3656 1011792 1% /run
tmpfs 507724 28668 479056 6% /run/lock
tmpfs 1015448 0 1015448 0% /sys/fs/cgroup
/dev/md127 8776243968 4750400404 3986770748 55% /data
/dev/md127 8776243968 4750400404 3986770748 55% /home
/dev/md127 8776243968 4750400404 3986770748 55% /apps
/dev/md127 8776243968 4750400404 3986770748 55% /var/ftp/Backup
/dev/md127 8776243968 4750400404 3986770748 55% /run/nfs4/data/Software
