defcon84
Jun 20, 2018Guide
ReadyDR Error 255
I have a share with 422GB ReadyNAS 314 (v6.9.2) that i want to backup to a ReadyNAS 3312 (v6.9.3).
All goes well for 30 minutes, then i get:
"ReadyDR job failure: Unknown error 255 [Backup to NS5...
- Jun 26, 2018
Hi defcon84,
The 'Broken pipe' status indicates a network issue. Are both NAS devices connected on the same LAN? Are they connected to a switch or are they connected directly to the router?
JohnCM_S
Jun 20, 2018NETGEAR Employee Retired
Hi defcon84,
Can you download the system logs and provide it to us. You may check this link for the steps on how you can send it.
defcon84
Jun 21, 2018Guide
One NAS is online for 3 years and thus has many many logs.
Therefor I'm getting a timeout on the download logs (/dbbroker) page.
I can SSH into the NAS and get the files manually, which files do you need?
- StephenBJun 21, 2018Guru - Experienced User
The logs are rotated, so that shouldn't be giving you a timeout.
I suggest going in with ssh, and looking at the fullness of the OS partition next.
Another option is to use paid support (my.netgear.com), and give netgear remote access.
- defcon84Jun 22, 2018Guide
Is this what you need?
root@SKNAS02:/# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 4192192 660984 2862776 19% /
tmpfs 1015448 0 1015448 0% /dev/shm
tmpfs 1015448 3656 1011792 1% /run
tmpfs 507724 28668 479056 6% /run/lock
tmpfs 1015448 0 1015448 0% /sys/fs/cgroup
/dev/md127 8776243968 4750400404 3986770748 55% /data
/dev/md127 8776243968 4750400404 3986770748 55% /home
/dev/md127 8776243968 4750400404 3986770748 55% /apps
/dev/md127 8776243968 4750400404 3986770748 55% /var/ftp/Backup
/dev/md127 8776243968 4750400404 3986770748 55% /run/nfs4/data/Software - defcon84Jun 22, 2018Guide
test
I thought i'd try an r-sync copy
Backup Job Name: Backup/SomeFolder -> NAS Backup Job Type: Full Protocol: rsync Backup Source: [Backup2]/ Backup Destination: [remote:rsync]/10.0.x.x::Backup/SomeFolder Backup Start Time: Fri Jun 22 2018 9:03:46 Backup Finish Time: Fri Jun 22 2018 10:11:26 Backup Status: Fail: Failure during copy. Failed to run rsync, return rc 10 'rsync' command returns rc=10 sending incremental file list Backup/SomeFolder/SomeFile.bak 80,080 0% 0.00kB/s 0:00:00 99,939,840 0% 95.23MB/s 0:03:45 199,639,440 0% 95.16MB/s 0:03:44 299,018,720 1% 95.06MB/s 0:03:43 398,638,240 1% 95.07MB/s 0:03:42 498,337,840 2% 95.06MB/s 0:03:41 598,918,320 2% 95.24MB/s 0:03:40 699,498,800 3% 95.53MB/s 0:03:38 800,800,000 3% 95.93MB/s 0:03:36 901,140,240 4% 96.06MB/s 0:03:35 1,001,880,880 4% 96.12MB/s 0:03:33 1,102,060,960 4% 96.03MB/s 0:03:33 1,201,440,240 5% 95.57MB/s 0:03:33 1,301,620,320 5% 95.53MB/s 0:03:32 1,401,640,240 6% 95.36MB/s 0:03:31 1,502,140,640 6% 95.43MB/s 0:03:30 1,603,201,600 7% 95.84MB/s 0:03:28 1,703,942,240 7% 95.97MB/s 0:03:27 1,805,243,440 8% 96.27MB/s 0:03:25 1,905,984,080 8% 96.33MB/s 0:03:24 2,006,724,720 9% 96.26MB/s 0:03:23 2,107,545,440 9% 96.27MB/s 0:03:22 2,207,645,440 10% 95.99MB/s 0:03:21 2,306,143,840 10% 95.45MB/s 0:03:22 2,405,523,120 10% 95.13MB/s 0:03:21 2,505,943,440 11% 95.01MB/s 0:03:20 2,607,004,400 11% 95.24MB/s 0:03:19 2,706,864,160 12% 95.56MB/s 0:03:17 2,807,845,040 12% 95.97MB/s 0:03:15 2,907,945,040 13% 95.89MB/s 0:03:14 3,008,525,520 13% 95.75MB/s 0:03:14 3,107,984,880 14% 95.68MB/s 0:03:13 3,208,004,800 14% 95.45MB/s 0:03:12 3,308,104,800 14% 95.45MB/s 0:03:11 3,408,284,880 15% 95.36MB/s 0:03:10 3,508,865,360 15% 95.60MB/s 0:03:09 3,609,926,320 16% 95.85MB/s 0:03:07 3,710,987,280 16% 96.08MB/s 0:03:06 3,811,727,920 17% 96.21MB/s 0:03:05 3,912,228,320 17% 96.22MB/s 0:03:04 4,012,968,960 18% 96.14MB/s 0:03:03 4,113,709,600 18% 96.06MB/s 0:03:02 4,214,049,840 19% 95.92MB/s 0:03:01 4,314,470,160 19% 95.90MB/s 0:03:00 4,414,650,240 20% 95.77MB/s 0:02:59 4,515,390,880 20% 95.77MB/s 0:02:58 4,615,971,360 20% 95.85MB/s 0:02:57 4,717,112,400 21% 96.02MB/s 0:02:56 4,817,452,640 21% 96.08MB/s 0:02:55 4,917,312,400 22% 95.87MB/s 0:02:54 5,017,652,640 22% 95.79MB/s 0:02:53 5,117,672,560 23% 95.55MB/s 0:02:53 5,216,731,520 23% 95.24MB/s 0:02:52 5,315,630,320 24% 95.01MB/s 0:02:52 5,414,368,960 24% 94.66MB/s 0:02:51 5,514,549,040 25% 94.69MB/s 0:02:50 5,615,529,920 25% 95.15MB/s 0:02:48 5,716,270,560 25% 95.59MB/s 0:02:46 5,816,290,480 26% 95.85MB/s 0:02:45 5,916,070,160 26% 95.75MB/s 0:02:44 6,015,929,920 27% 95.49MB/s 0:02:44 6,116,190,080 27% 95.37MB/s 0:02:43 6,215,729,520 28% 95.28MB/s 0:02:42 6,315,509,200 28% 95.28MB/s 0:02:41 6,413,800,128 29% 94.76MB/s 0:02:41 6,414,619,328 29% 34.80MB/s 0:07:18 6,418,518,720 29% 23.63MB/s 0:10:46 6,422,483,648 29% 12.47MB/s 0:20:24 6,426,448,576 29% 1.48MB/s 2:52:26 6,430,413,504 29% 3.76MB/s 1:07:40 6,434,345,664 29% 3.76MB/s 1:07:31 6,438,310,592 29% 3.76MB/s 1:07:35 6,442,275,520 29% 3.76MB/s 1:07:34 6,446,240,448 29% 3.76MB/s 1:07:33 6,450,172,608 29% 3.76MB/s 1:07:28 6,454,104,768 29% 3.76MB/s 1:07:32 6,458,069,696 29% 3.76MB/s 1:07:34 6,462,067,392 29% 3.76MB/s 1:07:25 6,466,032,320 29% 3.77MB/s 1:07:17 6,469,997,248 29% 3.78MB/s 1:07:10 6,473,962,176 29% 3.78MB/s 1:07:06 6,477,927,104 29% 3.77MB/s 1:07:11 6,481,892,032 29% 3.77MB/s 1:07:12 6,485,889,728 29% 3.78MB/s 1:07:05 6,489,854,656 29% 3.77MB/s 1:07:07 6,493,819,584 29% 3.77MB/s 1:07:09 6,497,784,512 29% 3.77MB/s 1:07:11 6,501,716,672 29% 3.76MB/s 1:07:22 6,505,681,600 29% 3.76MB/s 1:07:17 6,509,646,528 29% 3.76MB/s 1:07:15 6,513,611,456 29% 3.76MB/s 1:07:16 6,517,576,384 29% 3.77MB/s 1:07:08 6,521,541,312 29% 3.77MB/s 1:07:07 6,525,506,240 29% 3.77MB/s 1:07:03 6,529,471,168 29% 3.77MB/s 1:06:58 6,533,468,864 29% 3.78MB/s 1:06:54 6,537,433,792 29% 3.77MB/s 1:06:57 6,541,398,720 29% 3.77MB/s 1:06:56 6,545,363,648 29% 3.77MB/s 1:06:53 6,549,328,576 29% 3.77MB/s 1:06:58 6,553,293,504 29% 3.77MB/s 1:06:52 6,557,258,432 29% 3.77MB/s 1:06:55 6,561,223,360 29% 3.77MB/s 1:06:54 6,565,188,288 29% 3.77MB/s 1:06:48 6,569,153,216 29% 3.77MB/s 1:06:47 6,573,150,912 29% 3.78MB/s 1:06:39 6,577,115,840 29% 3.78MB/s 1:06:41 6,581,080,768 29% 3.78MB/s 1:06:39 6,585,045,696 29% 3.78MB/s 1:06:38 6,589,010,624 29% 3.77MB/s 1:06:41 6,592,975,552 29% 3.78MB/s 1:06:37 6,596,874,944 29% 3.76MB/s 1:06:52 6,600,839,872 29% 3.76MB/s 1:06:53 6,604,804,800 29% 3.76MB/s 1:06:51 6,608,802,496 29% 3.77MB/s 1:06:40 6,612,767,424 29% 3.79MB/s 1:06:23 6,616,732,352 30% 3.78MB/s 1:06:24 6,620,697,280 30% 3.78MB/s 1:06:25 6,624,662,208 30% 3.77MB/s 1:06:33 6,628,627,136 30% 3.77MB/s 1:06:32 6,632,592,064 30% 3.77MB/s 1:06:32 6,636,524,224 30% 3.77MB/s 1:06:37 6,640,489,152 30% 3.77MB/s 1:06:37 6,644,454,080 30% 3.77MB/s 1:06:35 6,648,451,776 30% 3.77MB/s 1:06:27 6,652,416,704 30% 3.78MB/s 1:06:23 6,656,381,632 30% 3.77MB/s 1:06:25 6,660,346,560 30% 3.77MB/s 1:06:28 6,664,245,952 30% 3.75MB/s 1:06:45 6,668,243,648 30% 3.76MB/s 1:06:35 6,672,208,576 30% 3.76MB/s 1:06:36 6,676,173,504 30% 3.76MB/s 1:06:34 6,680,171,200 30% 3.78MB/s 1:06:15 6,684,168,896 30% 3.78MB/s 1:06:15 6,688,133,824 30% 3.78MB/s 1:06:07 6,692,098,752 30% 3.79MB/s 1:06:02 6,696,030,912 30% 3.78MB/s 1:06:12 6,699,995,840 30% 3.77MB/s 1:06:16 6,703,993,536 30% 3.77MB/s 1:06:14 6,707,958,464 30% 3.77MB/s 1:06:14 6,711,923,392 30% 3.78MB/s 1:06:08 6,715,888,320 30% 3.77MB/s 1:06:11 6,719,853,248 30% 3.76MB/s 1:06:18 6,723,752,640 30% 3.75MB/s 1:06:33 6,727,717,568 30% 3.75MB/s 1:06:29 6,731,682,496 30% 3.76MB/s 1:06:22 6,735,647,424 30% 3.76MB/s 1:06:22 6,739,579,584 30% 3.76MB/s 1:06:15 6,743,544,512 30% 3.76MB/s 1:06:15 6,747,509,440 30% 3.76MB/s 1:06:16 6,751,441,600 30% 3.76MB/s 1:06:19 6,755,406,528 30% 3.77MB/s 1:06:05 6,759,371,456 30% 3.77MB/s 1:06:02 6,763,369,152 30% 3.78MB/s 1:05:55 6,767,366,848 30% 3.79MB/s 1:05:40 6,771,331,776 30% 3.79MB/s 1:05:39 6,775,296,704 30% 3.79MB/s 1:05:41 6,779,261,632 30% 3.78MB/s 1:05:45 6,783,128,256 30% 3.75MB/s 1:06:14 6,787,093,184 30% 3.75MB/s 1:06:19 6,791,058,112 30% 3.74MB/s 1:06:21 6,795,023,040 30% 3.75MB/s 1:06:18 6,798,987,968 30% 3.77MB/s 1:05:49 6,802,985,664 30% 3.78MB/s 1:05:38 6,806,983,360 30% 3.79MB/s 1:05:26 6,810,948,288 30% 3.79MB/s 1:05:28 6,814,913,216 30% 3.79MB/s 1:05:29 6,818,878,144 30% 3.79MB/s 1:05:30 6,822,875,840 30% 3.78MB/s 1:05:37 6,826,840,768 30% 3.78MB/s 1:05:33 6,830,772,928 30% 3.77MB/s 1:05:40 6,834,737,856 30% 3.77MB/s 1:05:45 6,838,702,784 31% 3.77MB/s 1:05:43 6,842,634,944 31% 3.76MB/s 1:05:53 6,846,599,872 31% 3.76MB/s 1:05:44 6,850,564,800 31% 3.77MB/s 1:05:38 6,854,529,728 31% 3.76MB/s 1:05:43 6,858,494,656 31% 3.77MB/s 1:05:34 6,862,459,584 31% 3.77MB/s 1:05:35 6,866,457,280 31% 3.77MB/s 1:05:30 6,870,454,976 31% 3.78MB/s 1:05:21 6,874,419,904 31% 3.78MB/s 1:05:18 6,878,352,064 31% 3.77MB/s 1:05:29 6,882,316,992 31% 3.77MB/s 1:05:31 6,886,281,920 31% 3.76MB/s 1:05:36 6,890,246,848 31% 3.76MB/s 1:05:39 6,894,211,776 31% 3.77MB/s 1:05:26 6,898,209,472 31% 3.78MB/s 1:05:18 6,902,207,168 31% 3.79MB/s 1:05:08 6,906,139,328 31% 3.78MB/s 1:05:17 6,910,137,024 31% 3.78MB/s 1:05:11 6,914,069,184 31% 3.76MB/s 1:05:28 6,918,034,112 31% 3.76MB/s 1:05:32 6,921,999,040 31% 3.77MB/s 1:05:20 6,925,963,968 31% 3.77MB/s 1:05:23 6,929,928,896 31% 3.77MB/s 1:05:13 6,933,861,056 31% 3.76MB/s 1:05:22 6,937,858,752 31% 3.77MB/s 1:05:16 6,941,856,448 31% 3.78MB/s 1:05:07 6,945,854,144 31% 3.78MB/s 1:05:00 6,949,819,072 31% 3.79MB/s 1:04:47 6,953,784,000 31% 3.79MB/s 1:04:55 6,957,781,696 31% 3.78MB/s 1:04:56 6,961,713,856 31% 3.77MB/s 1:05:06 6,965,711,552 31% 3.77MB/s 1:05:04 6,969,709,248 31% 3.78MB/s 1:04:58 6,973,674,176 31% 3.77MB/s 1:05:07 6,977,639,104 31% 3.78MB/s 1:05:00 6,981,636,800 31% 3.78MB/s 1:04:54 6,985,601,728 31% 3.77MB/s 1:04:58 6,989,533,888 31% 3.77MB/s 1:05:02 6,993,498,816 31% 3.77MB/s 1:05:02 6,997,430,976 31% 3.76MB/s 1:05:15 7,001,395,904 31% 3.76MB/s 1:05:11 7,005,360,832 31% 3.77MB/s 1:04:59 7,009,358,528 31% 3.78MB/s 1:04:51 7,013,290,688 31% 3.78MB/s 1:04:50 7,017,255,616 31% 3.77MB/s 1:04:55 7,021,220,544 31% 3.77MB/s 1:04:56 7,025,185,472 31% 3.76MB/s 1:05:01 7,029,150,400 31% 3.77MB/s 1:04:53 7,033,115,328 31% 3.77MB/s 1:04:50 7,037,080,256 31% 3.77MB/s 1:04:48 7,041,012,416 31% 3.76MB/s 1:05:01 7,045,010,112 31% 3.77MB/s 1:04:48 7,048,975,040 31% 3.77MB/s 1:04:44 7,052,939,968 31% 3.77MB/s 1:04:41 7,056,904,896 31% 3.78MB/s 1:04:32 7,060,869,824 32% 3.77MB/s 1:04:41 7,064,834,752 32% 3.77MB/s 1:04:41 7,068,734,144 32% 3.75MB/s 1:04:58 7,072,699,072 32% 3.75MB/s 1:04:58 7,076,664,000 32% 3.76MB/s 1:04:55 7,080,628,928 32% 3.76MB/s 1:04:50 7,084,561,088 32% 3.76MB/s 1:04:45 7,088,526,016 32% 3.76MB/s 1:04:44 7,092,490,944 32% 3.76MB/s 1:04:50 7,096,390,336 32% 3.74MB/s 1:05:10 7,100,355,264 32% 3.75MB/s 1:04:59 7,104,320,192 32% 3.75MB/s 1:04:55 7,108,285,120 32% 3.75MB/s 1:04:48 7,112,250,048 32% 3.77MB/s 1:04:27 7,116,214,976 32% 3.78MB/s 1:04:24 7,120,179,904 32% 3.78MB/s 1:04:22 7,124,079,296 32% 3.75MB/s 1:04:43 7,128,044,224 32% 3.75MB/s 1:04:46 7,132,009,152 32% 3.75MB/s 1:04:42 7,135,974,080 32% 3.75MB/s 1:04:40 7,139,939,008 32% 3.78MB/s 1:04:15 7,143,936,704 32% 3.78MB/s 1:04:08 7,147,901,632 32% 3.78MB/s 1:04:07 7,151,801,024 32% 3.77MB/s 1:04:20 7,155,798,720 32% 3.77MB/s 1:04:20 7,159,763,648 32% 3.76MB/s 1:04:25 7,163,728,576 32% 3.76MB/s 1:04:27 7,167,693,504 32% 3.78MB/s 1:04:09 7,171,658,432 32% 3.77MB/s 1:04:10 7,175,623,360 32% 3.78MB/s 1:04:08 7,179,522,752 32% 3.76MB/s 1:04:23 7,183,520,448 32% 3.76MB/s 1:04:19 7,187,485,376 32% 3.76MB/s 1:04:18 7,191,483,072 32% 3.77MB/s 1:04:13 7,195,415,232 32% 3.78MB/s 1:04:03 7,199,412,928 32% 3.77MB/s 1:04:05 7,203,377,856 32% 3.78MB/s 1:04:01 7,207,310,016 32% 3.76MB/s 1:04:14 7,211,242,176 32% 3.76MB/s 1:04:18 7,215,207,104 32% 3.76MB/s 1:04:19 7,219,172,032 32% 3.75MB/s 1:04:21 7,223,136,960 32% 3.76MB/s 1:04:10 7,227,101,888 32% 3.77MB/s 1:03:56 7,231,066,816 32% 3.78MB/s 1:03:53 7,234,998,976 32% 3.76MB/s 1:04:05 7,238,963,904 32% 3.77MB/s 1:04:02 7,242,928,832 32% 3.77MB/s 1:04:00 7,246,893,760 32% 3.76MB/s 1:04:01 7,250,825,920 32% 3.77MB/s 1:03:56 7,254,823,616 32% 3.78MB/s 1:03:45 7,258,788,544 32% 3.77MB/s 1:03:49 7,262,687,936 32% 3.76MB/s 1:04:02 7,266,652,864 32% 3.77MB/s 1:03:54 7,270,617,792 32% 3.76MB/s 1:04:00 7,274,615,488 32% 3.77MB/s 1:03:52 7,278,580,416 33% 3.78MB/s 1:03:40 7,282,578,112 33% 3.78MB/s 1:03:35 7,286,543,040 33% 3.78MB/s 1:03:36 7,290,442,432 33% 3.76MB/s 1:03:55 7,294,440,128 33% 3.77MB/s 1:03:47 7,298,437,824 33% 3.77MB/s 1:03:47 7,302,402,752 33% 3.76MB/s 1:03:48 7,306,367,680 33% 3.78MB/s 1:03:33 7,310,332,608 33% 3.77MB/s 1:03:36 7,314,297,536 33% 3.77MB/s 1:03:38 7,318,229,696 33% 3.76MB/s 1:03:47 7,322,194,624 33% 3.76MB/s 1:03:45 7,326,192,320 33% 3.76MB/s 1:03:41 7,330,157,248 33% 3.77MB/s 1:03:38 7,334,122,176 33% 3.78MB/s 1:03:27 7,338,087,104 33% 3.78MB/s 1:03:23 7,342,052,032 33% 3.78MB/s 1:03:22 7,345,951,424 33% 3.76MB/s 1:03:42 7,349,949,120 33% 3.76MB/s 1:03:34 7,353,914,048 33% 3.76MB/s 1:03:34 7,357,878,976 33% 3.76MB/s 1:03:32 7,361,843,904 33% 3.79MB/s 1:03:10 7,365,808,832 33% 3.78MB/s 1:03:13 7,369,806,528 33% 3.79MB/s 1:03:07 7,373,705,920 33% 3.77MB/s 1:03:24 7,377,670,848 33% 3.77MB/s 1:03:25 7,381,635,776 33% 3.76MB/s 1:03:27 7,385,600,704 33% 3.76MB/s 1:03:33 7,389,565,632 33% 3.77MB/s 1:03:16 7,393,530,560 33% 3.77MB/s 1:03:14 7,397,528,256 33% 3.78MB/s 1:03:08 7,401,427,648 33% 3.77MB/s 1:03:20 7,405,392,576 33% 3.76MB/s 1:03:19 7,409,390,272 33% 3.77MB/s 1:03:15 7,413,355,200 33% 3.76MB/s 1:03:22 7,417,320,128 33% 3.77MB/s 1:03:10 7,421,317,824 33% 3.77MB/s 1:03:06 7,425,315,520 33% 3.78MB/s 1:03:02 7,429,280,448 33% 3.78MB/s 1:03:02 7,433,245,376 33% 3.78MB/s 1:02:55 7,437,243,072 33% 3.78MB/s 1:02:52 7,441,175,232 33% 3.77MB/s 1:03:03 7,445,140,160 33% 3.78MB/s 1:02:55 7,449,072,320 33% 3.76MB/s 1:03:08 7,453,037,248 33% 3.76MB/s 1:03:15 7,456,969,408 33% 3.75MB/s 1:03:17 7,460,967,104 33% 3.76MB/s 1:03:09 7,464,964,800 33% 3.78MB/s 1:02:52 7,468,962,496 33% 3.78MB/s 1:02:46 7,472,960,192 33% 3.80MB/s 1:02:25 7,476,925,120 33% 3.79MB/s 1:02:34 7,480,922,816 33% 3.79MB/s 1:02:34 7,484,822,208 33% 3.77MB/s 1:02:50 7,488,787,136 33% 3.76MB/s 1:02:59 7,492,784,832 33% 3.77MB/s 1:02:54 7,496,782,528 33% 3.77MB/s 1:02:52 7,500,747,456 34% 3.78MB/s 1:02:37 7,504,712,384 34% 3.78MB/s 1:02:42 7,508,710,080 34% 3.78MB/s 1:02:38 7,512,642,240 34% 3.76MB/s 1:02:52 7,516,639,936 34% 3.77MB/s 1:02:47 7,520,604,864 34% 3.77MB/s 1:02:41 7,524,569,792 34% 3.77MB/s 1:02:44 7,528,567,488 34% 3.78MB/s 1:02:29 7,532,532,416 34% 3.78MB/s 1:02:33 7,536,530,112 34% 3.78MB/s 1:02:27 7,540,462,272 34% 3.77MB/s 1:02:39 7,544,394,432 34% 3.76MB/s 1:02:53 7,548,392,128 34% 3.76MB/s 1:02:45 7,552,357,056 34% 3.76MB/s 1:02:48 7,556,354,752 34% 3.77MB/s 1:02:31 7,560,319,680 34% 3.78MB/s 1:02:20 7,564,284,608 34% 3.78MB/s 1:02:23 7,568,216,768 34% 3.77MB/s 1:02:28 7,572,181,696 34% 3.77MB/s 1:02:30 7,576,146,624 34% 3.77MB/s 1:02:31 7,580,111,552 34% 3.77MB/s 1:02:31 7,584,076,480 34% 3.77MB/s 1:02:25 7,588,041,408 34% 3.77MB/s 1:02:24 7,592,039,104 34% 3.78MB/s 1:02:17 7,595,938,496 34% 3.76MB/s 1:02:30 7,599,903,424 34% 3.77MB/s 1:02:27 7,603,868,352 34% 3.76MB/s 1:02:28 7,607,833,280 34% 3.76MB/s 1:02:37 7,611,830,976 34% 3.77MB/s 1:02:18 7,615,795,904 34% 3.78MB/s 1:02:14 7,619,793,600 34% 3.78MB/s 1:02:11 7,623,725,760 34% 3.78MB/s 1:02:11 7,627,723,456 34% 3.78MB/s 1:02:10 7,631,721,152 34% 3.78MB/s 1:02:09 7,635,686,080 34% 3.78MB/s 1:02:08 7,639,683,776 34% 3.79MB/s 1:01:57 7,643,648,704 34% 3.78MB/s 1:02:01 7,647,613,632 34% 3.78MB/s 1:02:03 7,651,545,792 34% 3.77MB/s 1:02:15 7,655,510,720 34% 3.76MB/s 1:02:16 7,659,475,648 34% 3.76MB/s 1:02:14 7,663,440,576 34% 3.76MB/s 1:02:13 7,667,405,504 34% 3.77MB/s 1:02:06 7,671,370,432 34% 3.77MB/s 1:02:07 7,675,335,360 34% 3.77MB/s 1:02:05 7,679,234,752 34% 3.76MB/s 1:02:16 7,683,232,448 34% 3.77MB/s 1:02:06 7,687,164,608 34% 3.76MB/s 1:02:13 7,691,129,536 34% 3.76MB/s 1:02:14 7,695,094,464 34% 3.77MB/s 1:01:58 7,699,059,392 34% 3.77MB/s 1:02:00 7,703,024,320 34% 3.78MB/s 1:01:52 7,706,956,480 34% 3.77MB/s 1:01:59 7,710,921,408 34% 3.76MB/s 1:02:00
7,714,886,336 34% 3.77MB/s 1:01:58 7,718,884,032 34% 3.77MB/s 1:01:54 7,722,881,728 35% 3.78MB/s 1:01:38 7,726,846,656 35% 3.79MB/s 1:01:34 7,730,811,584 35% 3.79MB/s 1:01:34 7,734,743,744 35% 3.77MB/s 1:01:46 7,738,741,440 35% 3.77MB/s 1:01:49 7,742,706,368 35% 3.77MB/s 1:01:52 7,746,671,296 35% 3.77MB/s 1:01:51 7,750,636,224 35% 3.78MB/s 1:01:37 7,754,633,920 35% 3.78MB/s 1:01:36 7,758,598,848 35% 3.78MB/s 1:01:32 7,762,531,008 35% 3.77MB/s 1:01:39 7,766,528,704 35% 3.78MB/s 1:01:31 7,770,526,400 35% 3.78MB/s 1:01:28 7,774,491,328 35% 3.78MB/s 1:01:27 7,778,456,256 35% 3.79MB/s 1:01:16 7,782,421,184 35% 3.78MB/s 1:01:28 7,786,386,112 35% 3.77MB/s 1:01:32 7,790,318,272 35% 3.76MB/s 1:01:43 7,794,315,968 35% 3.76MB/s 1:01:41 7,798,280,896 35% 3.76MB/s 1:01:38 7,802,278,592 35% 3.77MB/s 1:01:34 7,806,243,520 35% 3.78MB/s 1:01:23 7,810,208,448 35% 3.77MB/s 1:01:27 7,814,173,376 35% 3.78MB/s 1:01:22 7,818,105,536 35% 3.76MB/s 1:01:33 7,822,070,464 35% 3.76MB/s 1:01:36 7,826,068,160 35% 3.77MB/s 1:01:29 7,830,065,856 35% 3.77MB/s 1:01:27 7,834,030,784 35% 3.78MB/s 1:01:16 7,837,995,712 35% 3.78MB/s 1:01:11 7,841,993,408 35% 3.78MB/s 1:01:07 7,845,925,568 35% 3.77MB/s 1:01:20 7,849,923,264 35% 3.77MB/s 1:01:17 7,853,888,192 35% 3.77MB/s 1:01:17 7,857,885,888 35% 3.77MB/s 1:01:18 7,861,850,816 35% 3.78MB/s 1:01:04 7,865,815,744 35% 3.78MB/s 1:01:06 7,869,780,672 35% 3.78MB/s 1:01:08 7,873,712,832 35% 3.76MB/s 1:01:22 7,877,710,528 35% 3.76MB/s 1:01:18 7,881,675,456 35% 3.76MB/s 1:01:18 7,885,640,384 35% 3.77MB/s 1:01:14 7,889,605,312 35% 3.78MB/s 1:01:01 7,893,603,008 35% 3.78MB/s 1:00:59 7,897,567,936 35% 3.78MB/s 1:00:55 7,901,500,096 35% 3.77MB/s 1:01:04 7,905,497,792 35% 3.78MB/s 1:00:59 7,909,397,184 35% 3.76MB/s 1:01:16 7,913,362,112 35% 3.76MB/s 1:01:17 7,917,327,040 35% 3.77MB/s 1:01:05 7,921,291,968 35% 3.76MB/s 1:01:11 7,925,224,128 35% 3.77MB/s 1:01:02 7,929,156,288 35% 3.76MB/s 1:01:13 7,933,121,216 35% 3.76MB/s 1:01:12 7,937,118,912 35% 3.76MB/s 1:01:03 7,941,116,608 36% 3.78MB/s 1:00:50 7,945,114,304 36% 3.79MB/s 1:00:35 7,949,112,000 36% 3.80MB/s 1:00:28 7,953,109,696 36% 3.79MB/s 1:00:30 7,957,009,088 36% 3.77MB/s 1:00:49 7,960,974,016 36% 3.77MB/s 1:00:50 7,964,938,944 36% 3.76MB/s 1:00:56 7,968,936,640 36% 3.76MB/s 1:00:53 7,972,901,568 36% 3.78MB/s 1:00:39 7,976,899,264 36% 3.78MB/s 1:00:35 7,980,896,960 36% 3.79MB/s 1:00:29 7,984,829,120 36% 3.77MB/s 1:00:40 7,988,826,816 36% 3.78MB/s 1:00:33 7,992,824,512 36% 3.78MB/s 1:00:31 7,996,789,440 36% 3.78MB/s 1:00:32 8,000,787,136 36% 3.79MB/s 1:00:19 8,004,752,064 36% 3.79MB/s 1:00:24 8,008,716,992 36% 3.78MB/s 1:00:27 8,012,649,152 36% 3.77MB/s 1:00:39 8,016,614,080 36% 3.76MB/s 1:00:44 8,020,480,704 36% 3.74MB/s 1:01:03 8,024,445,632 36% 3.74MB/s 1:01:02 8,028,410,560 36% 3.75MB/s 1:00:49 8,032,375,488 36% 3.75MB/s 1:00:46 8,036,340,416 36% 3.77MB/s 1:00:26 8,040,239,808 36% 3.76MB/s 1:00:41 8,044,204,736 36% 3.75MB/s 1:00:45 8,048,169,664 36% 3.76MB/s 1:00:42 8,052,134,592 36% 3.76MB/s 1:00:37 8,056,099,520 36% 3.77MB/s 1:00:24 8,060,097,216 36% 3.78MB/s 1:00:14 8,064,062,144 36% 3.78MB/s 1:00:17 8,067,994,304 36% 3.77MB/s 1:00:27 8,071,959,232 36% 3.77MB/s 1:00:26 8,075,924,160 36% 3.76MB/s 1:00:28 8,079,921,856 36% 3.77MB/s 1:00:22 8,083,821,248 36% 3.76MB/s 1:00:23 8,087,786,176 36% 3.77MB/s 1:00:21 8,091,751,104 36% 3.77MB/s 1:00:20 8,095,683,264 36% 3.75MB/s 1:00:30 8,099,648,192 36% 3.77MB/s 1:00:16 8,103,645,888 36% 3.77MB/s 1:00:12 8,107,643,584 36% 3.77MB/s 1:00:10 8,111,641,280 36% 3.79MB/s 0:59:55 8,115,606,208 36% 3.79MB/s 0:59:54 8,119,571,136 36% 3.78MB/s 0:59:55 8,123,503,296 36% 3.77MB/s 1:00:05 8,127,500,992 36% 3.77MB/s 1:00:04 8,131,465,920 36% 3.77MB/s 1:00:05 8,135,463,616 36% 3.78MB/s 1:00:00 8,139,395,776 36% 3.78MB/s 0:59:57 8,143,393,472 36% 3.78MB/s 0:59:57 8,147,358,400 36% 3.78MB/s 0:59:54 8,151,257,792 36% 3.76MB/s 1:00:13 8,155,222,720 36% 3.76MB/s 1:00:09 8,159,154,880 36% 3.74MB/s 1:00:23 8,163,119,808 37% 3.74MB/s 1:00:26 8,167,084,736 37% 3.75MB/s 1:00:13 8,171,049,664 37% 3.76MB/s 1:00:06 8,175,014,592 37% 3.77MB/s 0:59:51 8,178,913,984 37% 3.76MB/s 1:00:02 8,182,878,912 37% 3.77MB/s 0:59:57 8,186,843,840 37% 3.77MB/s 0:59:56 8,190,808,768 37% 3.76MB/s 0:59:59 8,194,806,464 37% 3.78MB/s 0:59:42 8,198,804,160 37% 3.78MB/s 0:59:39 8,202,769,088 37% 3.78MB/s 0:59:38 8,206,734,016 37% 3.78MB/s 0:59:37 8,210,698,944 37% 3.78MB/s 0:59:38 8,214,696,640 37% 3.78MB/s 0:59:37 8,218,628,800 37% 3.77MB/s 0:59:46 8,222,593,728 37% 3.78MB/s 0:59:37 8,226,558,656 37% 3.77MB/s 0:59:37 8,230,523,584 37% 3.77MB/s 0:59:45 8,234,455,744 37% 3.77MB/s 0:59:43 8,238,420,672 37% 3.76MB/s 0:59:43 8,242,385,600 37% 3.76MB/s 0:59:44 8,246,350,528 37% 3.77MB/s 0:59:37 8,250,315,456 37% 3.78MB/s 0:59:28 8,254,280,384 37% 3.78MB/s 0:59:26 8,258,245,312 37% 3.78MB/s 0:59:28 8,262,177,472 37% 3.76MB/s 0:59:38 8,266,142,400 37% 3.76MB/s 0:59:41 8,270,107,328 37% 3.76MB/s 0:59:39 8,274,105,024 37% 3.77MB/s 0:59:34 8,278,102,720 37% 3.78MB/s 0:59:20 8,282,100,416 37% 3.79MB/s 0:59:12 8,286,032,576 37% 3.78MB/s 0:59:18 8,289,997,504 37% 3.78MB/s 0:59:17 8,293,962,432 37% 3.78MB/s 0:59:18 8,297,927,360 37% 3.77MB/s 0:59:23 8,301,892,288 37% 3.78MB/s 0:59:14 8,305,889,984 37% 3.78MB/s 0:59:09 8,309,887,680 37% 3.79MB/s 0:59:05 8,313,787,072 37% 3.77MB/s 0:59:17 8,317,752,000 37% 3.77MB/s 0:59:17 8,321,716,928 37% 3.77MB/s 0:59:19 8,325,681,856 37% 3.76MB/s 0:59:24 8,329,646,784 37% 3.78MB/s 0:59:09 8,333,611,712 37% 3.77MB/s 0:59:10 8,337,576,640 37% 3.77MB/s 0:59:14 8,341,476,032 37% 3.76MB/s 0:59:25 8,345,440,960 37% 3.75MB/s 0:59:27 8,349,438,656 37% 3.76MB/s 0:59:17 8,353,403,584 37% 3.76MB/s 0:59:14 8,357,368,512 37% 3.78MB/s 0:59:00 8,361,333,440 37% 3.78MB/s 0:58:56 8,365,298,368 37% 3.78MB/s 0:59:00 8,369,230,528 37% 3.77MB/s 0:59:09 8,373,195,456 37% 3.77MB/s 0:59:08 8,377,160,384 37% 3.76MB/s 0:59:08 8,381,125,312 38% 3.76MB/s 0:59:13 8,385,090,240 38% 3.77MB/s 0:59:04 8,389,055,168 38% 3.77MB/s 0:59:04 8,393,020,096 38% 3.76MB/s 0:59:05 8,396,853,952 38% 3.74MB/s 0:59:27 8,400,818,880 38% 3.74MB/s 0:59:27 8,404,783,808 38% 3.74MB/s 0:59:23 8,408,748,736 38% 3.75MB/s 0:59:17 8,412,713,664 38% 3.77MB/s 0:58:49 8,416,711,360 38% 3.78MB/s 0:58:40 8,420,676,288 38% 3.79MB/s 0:58:36 8,424,608,448 38% 3.77MB/s 0:58:48 8,428,606,144 38% 3.78MB/s 0:58:41 8,432,571,072 38% 3.77MB/s 0:58:46 8,436,536,000 38% 3.77MB/s 0:58:49 8,440,500,928 38% 3.78MB/s 0:58:40 8,444,465,856 38% 3.77MB/s 0:58:43 8,448,463,552 38% 3.77MB/s 0:58:40 8,452,362,944 38% 3.76MB/s 0:58:57 8,456,327,872 38% 3.76MB/s 0:58:52 8,460,260,032 38% 3.75MB/s 0:59:02 8,464,224,960 38% 3.75MB/s 0:59:01 8,468,189,888 38% 3.77MB/s 0:58:41 8,472,187,584 38% 3.77MB/s 0:58:37 8,476,152,512 38% 3.78MB/s 0:58:25 8,480,084,672 38% 3.77MB/s 0:58:36 8,484,049,600 38% 3.77MB/s 0:58:38 8,488,014,528 38% 3.76MB/s 0:58:39 8,492,012,224 38% 3.77MB/s 0:58:34 8,495,911,616 38% 3.76MB/s 0:58:37 8,499,876,544 38% 3.76MB/s 0:58:36 8,503,841,472 38% 3.76MB/s 0:58:38 8,507,740,864 38% 3.74MB/s 0:58:55 8,511,738,560 38% 3.76MB/s 0:58:35 8,515,736,256 38% 3.77MB/s 0:58:27 8,519,701,184 38% 3.77MB/s 0:58:26 8,523,666,112 38% 3.78MB/s 0:58:12 8,527,663,808 38% 3.78MB/s 0:58:11 8,531,628,736 38% 3.78MB/s 0:58:15 8,535,560,896 38% 3.77MB/s 0:58:24 8,539,525,824 38% 3.76MB/s 0:58:27 8,543,490,752 38% 3.76MB/s 0:58:29 8,547,455,680 38% 3.76MB/s 0:58:29 8,551,420,608 38% 3.77MB/s 0:58:15 8,555,385,536 38% 3.78MB/s 0:58:10 8,559,350,464 38% 3.78MB/s 0:58:07 8,563,249,856 38% 3.76MB/s 0:58:19 8,567,214,784 38% 3.76MB/s 0:58:20 8,571,212,480 38% 3.76MB/s 0:58:18 8,575,177,408 38% 3.76MB/s 0:58:17 8,579,175,104 38% 3.78MB/s 0:57:57 8,583,172,800 38% 3.79MB/s 0:57:51 8,587,137,728 38% 3.79MB/s 0:57:52 8,591,069,888 38% 3.77MB/s 0:58:04 8,595,034,816 38% 3.77MB/s 0:58:08 8,599,032,512 38% 3.77MB/s 0:58:07 8,602,997,440 39% 3.77MB/s 0:58:04 8,606,962,368 39% 3.78MB/s 0:57:53 8,610,894,528 39% 3.77MB/s 0:58:00 8,614,859,456 39% 3.77MB/s 0:58:02 8,618,758,848 39% 3.75MB/s 0:58:16 8,622,723,776 39% 3.75MB/s 0:58:13 8,626,721,472 39% 3.77MB/s 0:57:59 8,630,686,400 39% 3.77MB/s 0:57:59 8,634,618,560 39% 3.77MB/s 0:57:55 8,638,583,488 39% 3.77MB/s 0:57:55 8,642,548,416 39% 3.76MB/s 0:57:59 8,646,447,808 39% 3.75MB/s 0:58:12 8,650,412,736 39% 3.76MB/s 0:58:02 8,654,377,664 39% 3.76MB/s 0:58:01 8,658,342,592 39% 3.76MB/s 0:58:00 8,662,340,288 39% 3.78MB/s 0:57:42 8,666,337,984 39% 3.78MB/s 0:57:37 8,670,335,680 39% 3.79MB/s 0:57:29 8,674,267,840 39% 3.78MB/s 0:57:32 8,678,265,536 39% 3.79MB/s 0:57:29 8,682,230,464 39% 3.78MB/s 0:57:32 8,686,195,392 39% 3.78MB/s 0:57:37 8,690,160,320 39% 3.78MB/s 0:57:29 8,694,125,248 39% 3.78MB/s 0:57:34 8,698,122,944 39% 3.78MB/s 0:57:27 8,702,055,104 39% 3.77MB/s 0:57:34 8,706,052,800 39% 3.78MB/s 0:57:24 8,710,050,496 39% 3.79MB/s 0:57:18 8,714,048,192 39% 3.79MB/s 0:57:19 8,718,045,888 39% 3.80MB/s 0:57:06 8,722,010,816 39% 3.79MB/s 0:57:13 8,726,008,512 39% 3.80MB/s 0:57:09 8,729,907,904 39% 3.78MB/s 0:57:24 8,733,807,296 39% 3.76MB/s 0:57:41 8,737,739,456 39% 3.75MB/s 0:57:46 8,741,704,384 39% 3.74MB/s 0:57:51 8,745,669,312 39% 3.76MB/s 0:57:39 8,749,634,240 39% 3.77MB/s 0:57:24 8,753,599,168 39% 3.78MB/s 0:57:17 8,757,531,328 39% 3.77MB/s 0:57:27 8,761,529,024 39% 3.77MB/s 0:57:21 8,765,526,720 39% 3.77MB/s 0:57:18 8,769,524,416 39% 3.78MB/s 0:57:13 8,773,489,344 39% 3.79MB/s 0:57:02 8,777,454,272 39% 3.79MB/s 0:57:03 8,781,451,968 39% 3.79MB/s 0:56:59 8,785,384,128 39% 3.78MB/s 0:57:11 8,789,349,056 39% 3.77MB/s 0:57:15 8,793,313,984 39% 3.77MB/s 0:57:16 8,797,278,912 39% 3.76MB/s 0:57:20 8,801,243,840 39% 3.77MB/s 0:57:09 8,805,208,768 39% 3.78MB/s 0:57:04 8,809,173,696 39% 3.78MB/s 0:57:05 8,813,073,088 39% 3.76MB/s 0:57:18 8,817,070,784 39% 3.77MB/s 0:57:12 8,821,035,712 39% 3.76MB/s 0:57:14 8,824,967,872 40% 3.76MB/s 0:57:16 8,828,932,800 40% 3.77MB/s 0:57:01 8,832,897,728 40% 3.77MB/s 0:57:05 8,836,862,656 40% 3.77MB/s 0:57:00 8,840,794,816 40% 3.77MB/s 0:57:05 8,844,759,744 40% 3.77MB/s 0:57:04 8,848,757,440 40% 3.77MB/s 0:57:00 8,852,755,136 40% 3.77MB/s 0:56:55 8,856,720,064 40% 3.78MB/s 0:56:45 8,860,717,760 40% 3.79MB/s 0:56:41 8,864,715,456 40% 3.79MB/s 0:56:42 8,868,614,848 40% 3.77MB/s 0:56:57 8,872,547,008 40% 3.76MB/s 0:57:04 8,876,511,936 40% 3.75MB/s 0:57:08 8,880,476,864 40% 3.75MB/s 0:57:08 8,884,441,792 40% 3.77MB/s 0:56:55 8,888,406,720 40% 3.77MB/s 0:56:46 8,892,371,648 40% 3.78MB/s 0:56:43 8,896,271,040 40% 3.76MB/s 0:56:57 8,900,268,736 40% 3.77MB/s 0:56:50 8,904,266,432 40% 3.77MB/s 0:56:44 8,908,231,360 40% 3.77MB/s 0:56:42 8,912,229,056 40% 3.79MB/s 0:56:25 8,916,193,984 40% 3.78MB/s 0:56:30 8,920,158,912 40% 3.78MB/s 0:56:34 8,924,091,072 40% 3.77MB/s 0:56:43 8,928,056,000 40% 3.77MB/s 0:56:44 8,932,020,928 40% 3.77MB/s 0:56:42 8,935,985,856 40% 3.77MB/s 0:56:42 8,939,983,552 40% 3.78MB/s 0:56:28 8,943,948,480 40% 3.78MB/s 0:56:27 8,947,913,408 40% 3.78MB/s 0:56:26 8,951,845,568 40% 3.77MB/s 0:56:33 8,955,843,264 40% 3.77MB/s 0:56:34 8,959,808,192 40% 3.77MB/s 0:56:34 8,963,805,888 40% 3.77MB/s 0:56:29 8,967,770,816 40% 3.79MB/s 0:56:16 8,971,702,976 40% 3.77MB/s 0:56:27 8,975,667,904 40% 3.77MB/s 0:56:25 8,979,567,296 40% 3.75MB/s 0:56:43 8,983,532,224 40% 3.75MB/s 0:56:42 8,987,497,152 40% 3.76MB/s 0:56:31 8,991,494,848 40% 3.77MB/s 0:56:26 8,995,459,776 40% 3.78MB/s 0:56:12 8,999,424,704 40% 3.78MB/s 0:56:15 9,003,422,400 40% 3.78MB/s 0:56:11 9,007,354,560 40% 3.77MB/s 0:56:24 9,011,319,488 40% 3.76MB/s 0:56:26 9,015,317,184 40% 3.77MB/s 0:56:20 9,019,282,112 40% 3.76MB/s 0:56:23 9,023,214,272 40% 3.77MB/s 0:56:19 9,027,179,200 40% 3.77MB/s 0:56:15 9,031,144,128 40% 3.77MB/s 0:56:17 9,035,076,288 40% 3.75MB/s 0:56:26 9,039,041,216 40% 3.76MB/s 0:56:18 9,043,038,912 41% 3.77MB/s 0:56:11 9,047,036,608 41% 3.77MB/s 0:56:06 9,051,034,304 41% 3.79MB/s 0:55:51 9,054,999,232 41% 3.79MB/s 0:55:51 9,058,996,928 41% 3.79MB/s 0:55:51 9,062,929,088 41% 3.77MB/s 0:56:05 9,066,926,784 41% 3.77MB/s 0:56:05 9,070,957,248 41% 3.78MB/s 0:55:53 9,074,922,176 41% 3.78MB/s 0:55:55 9,078,919,872 41% 3.79MB/s 0:55:40 9,082,917,568 41% 3.79MB/s 0:55:38 9,086,882,496 41% 3.78MB/s 0:55:47 9,090,781,888 41% 3.77MB/s 0:56:00 9,094,714,048 41% 3.76MB/s 0:56:09 9,098,646,208 41% 3.75MB/s 0:56:18 9,102,611,136 41% 3.74MB/s 0:56:21 9,106,608,832 41% 3.76MB/s 0:56:04 9,110,540,992 41% 3.76MB/s 0:56:02 9,114,505,920 41% 3.77MB/s 0:55:53 9,118,438,080 41% 3.76MB/s 0:55:56 9,122,403,008 41% 3.76MB/s 0:55:57 9,126,400,704 41% 3.77MB/s 0:55:45 9,130,365,632 41% 3.77MB/s 0:55:48 9,134,330,560 41% 3.78MB/s 0:55:37 9,138,295,488 41% 3.78MB/s 0:55:35 9,142,293,184 41% 3.78MB/s 0:55:33 9,146,192,576 41% 3.77MB/s 0:55:43 9,150,157,504 41% 3.77MB/s 0:55:43 9,154,122,432 41% 3.77MB/s 0:55:45 9,157,989,056 41% 3.74MB/s 0:56:08 9,161,953,984 41% 3.75MB/s 0:55:54 9,165,918,912 41% 3.75MB/s 0:55:52 9,169,883,840 41% 3.76MB/s 0:55:49 9,173,783,232 41% 3.76MB/s 0:55:48 9,177,780,928 41% 3.76MB/s 0:55:42 9,181,745,856 41% 3.76MB/s 0:55:40 9,185,710,784 41% 3.76MB/s 0:55:41 9,189,675,712 41% 3.78MB/s 0:55:23 9,193,640,640 41% 3.77MB/s 0:55:28
