defcon84
Jun 20, 2018Guide
ReadyDR Error 255
I have a share with 422GB ReadyNAS 314 (v6.9.2) that i want to backup to a ReadyNAS 3312 (v6.9.3).
All goes well for 30 minutes, then i get:
"ReadyDR job failure: Unknown error 255 [Backup to NS5...
- Jun 26, 2018
Hi defcon84,
The 'Broken pipe' status indicates a network issue. Are both NAS devices connected on the same LAN? Are they connected to a switch or are they connected directly to the router?
defcon84
Jun 21, 2018Guide
One NAS is online for 3 years and thus has many many logs.
Therefor I'm getting a timeout on the download logs (/dbbroker) page.
I can SSH into the NAS and get the files manually, which files do you need?
Jun 21, 2018Guru - Experienced User
The logs are rotated, so that shouldn't be giving you a timeout.
I suggest going in with ssh, and looking at the fullness of the OS partition next.
Another option is to use paid support (my.netgear.com), and give netgear remote access.
- defcon84Jun 22, 2018Guide
Is this what you need?
root@SKNAS02:/# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 4 10236 1% /dev
/dev/md0 4192192 660984 2862776 19% /
tmpfs 1015448 0 1015448 0% /dev/shm
tmpfs 1015448 3656 1011792 1% /run
tmpfs 507724 28668 479056 6% /run/lock
tmpfs 1015448 0 1015448 0% /sys/fs/cgroup
/dev/md127 8776243968 4750400404 3986770748 55% /data
/dev/md127 8776243968 4750400404 3986770748 55% /home
/dev/md127 8776243968 4750400404 3986770748 55% /apps
/dev/md127 8776243968 4750400404 3986770748 55% /var/ftp/Backup
/dev/md127 8776243968 4750400404 3986770748 55% /run/nfs4/data/Software- StephenBJun 22, 2018Guru - Experienced User
This rules out any issues with OS partition free space.- defcon84Jun 22, 2018Guide
ok, so what is the next step?
test
I thought i'd try an r-sync copy
Backup Job Name: Backup/SomeFolder -> NAS Backup Job Type: Full Protocol: rsync Backup Source: [Backup2]/ Backup Destination: [remote:rsync]/10.0.x.x::Backup/SomeFolder Backup Start Time: Fri Jun 22 2018 9:03:46 Backup Finish Time: Fri Jun 22 2018 10:11:26 Backup Status: Fail: Failure during copy. Failed to run rsync, return rc 10 'rsync' command returns rc=10 sending incremental file list Backup/SomeFolder/SomeFile.bak 80,080 0% 0.00kB/s 0:00:00 99,939,840 0% 95.23MB/s 0:03:45 199,639,440 0% 95.16MB/s 0:03:44 299,018,720 1% 95.06MB/s 0:03:43 398,638,240 1% 95.07MB/s 0:03:42 498,337,840 2% 95.06MB/s 0:03:41 598,918,320 2% 95.24MB/s 0:03:40 699,498,800 3% 95.53MB/s 0:03:38 800,800,000 3% 95.93MB/s 0:03:36 901,140,240 4% 96.06MB/s 0:03:35 1,001,880,880 4% 96.12MB/s 0:03:33 1,102,060,960 4% 96.03MB/s 0:03:33 1,201,440,240 5% 95.57MB/s 0:03:33 1,301,620,320 5% 95.53MB/s 0:03:32 1,401,640,240 6% 95.36MB/s 0:03:31 1,502,140,640 6% 95.43MB/s 0:03:30 1,603,201,600 7% 95.84MB/s 0:03:28 1,703,942,240 7% 95.97MB/s 0:03:27 1,805,243,440 8% 96.27MB/s 0:03:25 1,905,984,080 8% 96.33MB/s 0:03:24 2,006,724,720 9% 96.26MB/s 0:03:23 2,107,545,440 9% 96.27MB/s 0:03:22 2,207,645,440 10% 95.99MB/s 0:03:21 2,306,143,840 10% 95.45MB/s 0:03:22 2,405,523,120 10% 95.13MB/s 0:03:21 2,505,943,440 11% 95.01MB/s 0:03:20 2,607,004,400 11% 95.24MB/s 0:03:19 2,706,864,160 12% 95.56MB/s 0:03:17 2,807,845,040 12% 95.97MB/s 0:03:15 2,907,945,040 13% 95.89MB/s 0:03:14 3,008,525,520 13% 95.75MB/s 0:03:14 3,107,984,880 14% 95.68MB/s 0:03:13 3,208,004,800 14% 95.45MB/s 0:03:12 3,308,104,800 14% 95.45MB/s 0:03:11 3,408,284,880 15% 95.36MB/s 0:03:10 3,508,865,360 15% 95.60MB/s 0:03:09 3,609,926,320 16% 95.85MB/s 0:03:07 3,710,987,280 16% 96.08MB/s 0:03:06 3,811,727,920 17% 96.21MB/s 0:03:05 3,912,228,320 17% 96.22MB/s 0:03:04 4,012,968,960 18% 96.14MB/s 0:03:03 4,113,709,600 18% 96.06MB/s 0:03:02 4,214,049,840 19% 95.92MB/s 0:03:01 4,314,470,160 19% 95.90MB/s 0:03:00 4,414,650,240 20% 95.77MB/s 0:02:59 4,515,390,880 20% 95.77MB/s 0:02:58 4,615,971,360 20% 95.85MB/s 0:02:57 4,717,112,400 21% 96.02MB/s 0:02:56 4,817,452,640 21% 96.08MB/s 0:02:55 4,917,312,400 22% 95.87MB/s 0:02:54 5,017,652,640 22% 95.79MB/s 0:02:53 5,117,672,560 23% 95.55MB/s 0:02:53 5,216,731,520 23% 95.24MB/s 0:02:52 5,315,630,320 24% 95.01MB/s 0:02:52 5,414,368,960 24% 94.66MB/s 0:02:51 5,514,549,040 25% 94.69MB/s 0:02:50 5,615,529,920 25% 95.15MB/s 0:02:48 5,716,270,560 25% 95.59MB/s 0:02:46 5,816,290,480 26% 95.85MB/s 0:02:45 5,916,070,160 26% 95.75MB/s 0:02:44 6,015,929,920 27% 95.49MB/s 0:02:44 6,116,190,080 27% 95.37MB/s 0:02:43 6,215,729,520 28% 95.28MB/s 0:02:42 6,315,509,200 28% 95.28MB/s 0:02:41 6,413,800,128 29% 94.76MB/s 0:02:41 6,414,619,328 29% 34.80MB/s 0:07:18 6,418,518,720 29% 23.63MB/s 0:10:46 6,422,483,648 29% 12.47MB/s 0:20:24 6,426,448,576 29% 1.48MB/s 2:52:26 6,430,413,504 29% 3.76MB/s 1:07:40 6,434,345,664 29% 3.76MB/s 1:07:31 6,438,310,592 29% 3.76MB/s 1:07:35 6,442,275,520 29% 3.76MB/s 1:07:34 6,446,240,448 29% 3.76MB/s 1:07:33 6,450,172,608 29% 3.76MB/s 1:07:28 6,454,104,768 29% 3.76MB/s 1:07:32 6,458,069,696 29% 3.76MB/s 1:07:34 6,462,067,392 29% 3.76MB/s 1:07:25 6,466,032,320 29% 3.77MB/s 1:07:17 6,469,997,248 29% 3.78MB/s 1:07:10 6,473,962,176 29% 3.78MB/s 1:07:06 6,477,927,104 29% 3.77MB/s 1:07:11 6,481,892,032 29% 3.77MB/s 1:07:12 6,485,889,728 29% 3.78MB/s 1:07:05 6,489,854,656 29% 3.77MB/s 1:07:07 6,493,819,584 29% 3.77MB/s 1:07:09 6,497,784,512 29% 3.77MB/s 1:07:11 6,501,716,672 29% 3.76MB/s 1:07:22 6,505,681,600 29% 3.76MB/s 1:07:17 6,509,646,528 29% 3.76MB/s 1:07:15 6,513,611,456 29% 3.76MB/s 1:07:16 6,517,576,384 29% 3.77MB/s 1:07:08 6,521,541,312 29% 3.77MB/s 1:07:07 6,525,506,240 29% 3.77MB/s 1:07:03 6,529,471,168 29% 3.77MB/s 1:06:58 6,533,468,864 29% 3.78MB/s 1:06:54 6,537,433,792 29% 3.77MB/s 1:06:57 6,541,398,720 29% 3.77MB/s 1:06:56 6,545,363,648 29% 3.77MB/s 1:06:53 6,549,328,576 29% 3.77MB/s 1:06:58 6,553,293,504 29% 3.77MB/s 1:06:52 6,557,258,432 29% 3.77MB/s 1:06:55 6,561,223,360 29% 3.77MB/s 1:06:54 6,565,188,288 29% 3.77MB/s 1:06:48 6,569,153,216 29% 3.77MB/s 1:06:47 6,573,150,912 29% 3.78MB/s 1:06:39 6,577,115,840 29% 3.78MB/s 1:06:41 6,581,080,768 29% 3.78MB/s 1:06:39 6,585,045,696 29% 3.78MB/s 1:06:38 6,589,010,624 29% 3.77MB/s 1:06:41 6,592,975,552 29% 3.78MB/s 1:06:37 6,596,874,944 29% 3.76MB/s 1:06:52 6,600,839,872 29% 3.76MB/s 1:06:53 6,604,804,800 29% 3.76MB/s 1:06:51 6,608,802,496 29% 3.77MB/s 1:06:40 6,612,767,424 29% 3.79MB/s 1:06:23 6,616,732,352 30% 3.78MB/s 1:06:24 6,620,697,280 30% 3.78MB/s 1:06:25 6,624,662,208 30% 3.77MB/s 1:06:33 6,628,627,136 30% 3.77MB/s 1:06:32 6,632,592,064 30% 3.77MB/s 1:06:32 6,636,524,224 30% 3.77MB/s 1:06:37 6,640,489,152 30% 3.77MB/s 1:06:37 6,644,454,080 30% 3.77MB/s 1:06:35 6,648,451,776 30% 3.77MB/s 1:06:27 6,652,416,704 30% 3.78MB/s 1:06:23 6,656,381,632 30% 3.77MB/s 1:06:25 6,660,346,560 30% 3.77MB/s 1:06:28 6,664,245,952 30% 3.75MB/s 1:06:45 6,668,243,648 30% 3.76MB/s 1:06:35 6,672,208,576 30% 3.76MB/s 1:06:36 6,676,173,504 30% 3.76MB/s 1:06:34 6,680,171,200 30% 3.78MB/s 1:06:15 6,684,168,896 30% 3.78MB/s 1:06:15 6,688,133,824 30% 3.78MB/s 1:06:07 6,692,098,752 30% 3.79MB/s 1:06:02 6,696,030,912 30% 3.78MB/s 1:06:12 6,699,995,840 30% 3.77MB/s 1:06:16 6,703,993,536 30% 3.77MB/s 1:06:14 6,707,958,464 30% 3.77MB/s 1:06:14 6,711,923,392 30% 3.78MB/s 1:06:08 6,715,888,320 30% 3.77MB/s 1:06:11 6,719,853,248 30% 3.76MB/s 1:06:18 6,723,752,640 30% 3.75MB/s 1:06:33 6,727,717,568 30% 3.75MB/s 1:06:29 6,731,682,496 30% 3.76MB/s 1:06:22 6,735,647,424 30% 3.76MB/s 1:06:22 6,739,579,584 30% 3.76MB/s 1:06:15 6,743,544,512 30% 3.76MB/s 1:06:15 6,747,509,440 30% 3.76MB/s 1:06:16 6,751,441,600 30% 3.76MB/s 1:06:19 6,755,406,528 30% 3.77MB/s 1:06:05 6,759,371,456 30% 3.77MB/s 1:06:02 6,763,369,152 30% 3.78MB/s 1:05:55 6,767,366,848 30% 3.79MB/s 1:05:40 6,771,331,776 30% 3.79MB/s 1:05:39 6,775,296,704 30% 3.79MB/s 1:05:41 6,779,261,632 30% 3.78MB/s 1:05:45 6,783,128,256 30% 3.75MB/s 1:06:14 6,787,093,184 30% 3.75MB/s 1:06:19 6,791,058,112 30% 3.74MB/s 1:06:21 6,795,023,040 30% 3.75MB/s 1:06:18 6,798,987,968 30% 3.77MB/s 1:05:49 6,802,985,664 30% 3.78MB/s 1:05:38 6,806,983,360 30% 3.79MB/s 1:05:26 6,810,948,288 30% 3.79MB/s 1:05:28 6,814,913,216 30% 3.79MB/s 1:05:29 6,818,878,144 30% 3.79MB/s 1:05:30 6,822,875,840 30% 3.78MB/s 1:05:37 6,826,840,768 30% 3.78MB/s 1:05:33 6,830,772,928 30% 3.77MB/s 1:05:40 6,834,737,856 30% 3.77MB/s 1:05:45 6,838,702,784 31% 3.77MB/s 1:05:43 6,842,634,944 31% 3.76MB/s 1:05:53 6,846,599,872 31% 3.76MB/s 1:05:44 6,850,564,800 31% 3.77MB/s 1:05:38 6,854,529,728 31% 3.76MB/s 1:05:43 6,858,494,656 31% 3.77MB/s 1:05:34 6,862,459,584 31% 3.77MB/s 1:05:35 6,866,457,280 31% 3.77MB/s 1:05:30 6,870,454,976 31% 3.78MB/s 1:05:21 6,874,419,904 31% 3.78MB/s 1:05:18 6,878,352,064 31% 3.77MB/s 1:05:29 6,882,316,992 31% 3.77MB/s 1:05:31 6,886,281,920 31% 3.76MB/s 1:05:36 6,890,246,848 31% 3.76MB/s 1:05:39 6,894,211,776 31% 3.77MB/s 1:05:26 6,898,209,472 31% 3.78MB/s 1:05:18 6,902,207,168 31% 3.79MB/s 1:05:08 6,906,139,328 31% 3.78MB/s 1:05:17 6,910,137,024 31% 3.78MB/s 1:05:11 6,914,069,184 31% 3.76MB/s 1:05:28 6,918,034,112 31% 3.76MB/s 1:05:32 6,921,999,040 31% 3.77MB/s 1:05:20 6,925,963,968 31% 3.77MB/s 1:05:23 6,929,928,896 31% 3.77MB/s 1:05:13 6,933,861,056 31% 3.76MB/s 1:05:22 6,937,858,752 31% 3.77MB/s 1:05:16 6,941,856,448 31% 3.78MB/s 1:05:07 6,945,854,144 31% 3.78MB/s 1:05:00 6,949,819,072 31% 3.79MB/s 1:04:47 6,953,784,000 31% 3.79MB/s 1:04:55 6,957,781,696 31% 3.78MB/s 1:04:56 6,961,713,856 31% 3.77MB/s 1:05:06 6,965,711,552 31% 3.77MB/s 1:05:04 6,969,709,248 31% 3.78MB/s 1:04:58 6,973,674,176 31% 3.77MB/s 1:05:07 6,977,639,104 31% 3.78MB/s 1:05:00 6,981,636,800 31% 3.78MB/s 1:04:54 6,985,601,728 31% 3.77MB/s 1:04:58 6,989,533,888 31% 3.77MB/s 1:05:02 6,993,498,816 31% 3.77MB/s 1:05:02 6,997,430,976 31% 3.76MB/s 1:05:15 7,001,395,904 31% 3.76MB/s 1:05:11 7,005,360,832 31% 3.77MB/s 1:04:59 7,009,358,528 31% 3.78MB/s 1:04:51 7,013,290,688 31% 3.78MB/s 1:04:50 7,017,255,616 31% 3.77MB/s 1:04:55 7,021,220,544 31% 3.77MB/s 1:04:56 7,025,185,472 31% 3.76MB/s 1:05:01 7,029,150,400 31% 3.77MB/s 1:04:53 7,033,115,328 31% 3.77MB/s 1:04:50 7,037,080,256 31% 3.77MB/s 1:04:48 7,041,012,416 31% 3.76MB/s 1:05:01 7,045,010,112 31% 3.77MB/s 1:04:48 7,048,975,040 31% 3.77MB/s 1:04:44 7,052,939,968 31% 3.77MB/s 1:04:41 7,056,904,896 31% 3.78MB/s 1:04:32 7,060,869,824 32% 3.77MB/s 1:04:41 7,064,834,752 32% 3.77MB/s 1:04:41 7,068,734,144 32% 3.75MB/s 1:04:58 7,072,699,072 32% 3.75MB/s 1:04:58 7,076,664,000 32% 3.76MB/s 1:04:55 7,080,628,928 32% 3.76MB/s 1:04:50 7,084,561,088 32% 3.76MB/s 1:04:45 7,088,526,016 32% 3.76MB/s 1:04:44 7,092,490,944 32% 3.76MB/s 1:04:50 7,096,390,336 32% 3.74MB/s 1:05:10 7,100,355,264 32% 3.75MB/s 1:04:59 7,104,320,192 32% 3.75MB/s 1:04:55 7,108,285,120 32% 3.75MB/s 1:04:48 7,112,250,048 32% 3.77MB/s 1:04:27 7,116,214,976 32% 3.78MB/s 1:04:24 7,120,179,904 32% 3.78MB/s 1:04:22 7,124,079,296 32% 3.75MB/s 1:04:43 7,128,044,224 32% 3.75MB/s 1:04:46 7,132,009,152 32% 3.75MB/s 1:04:42 7,135,974,080 32% 3.75MB/s 1:04:40 7,139,939,008 32% 3.78MB/s 1:04:15 7,143,936,704 32% 3.78MB/s 1:04:08 7,147,901,632 32% 3.78MB/s 1:04:07 7,151,801,024 32% 3.77MB/s 1:04:20 7,155,798,720 32% 3.77MB/s 1:04:20 7,159,763,648 32% 3.76MB/s 1:04:25 7,163,728,576 32% 3.76MB/s 1:04:27 7,167,693,504 32% 3.78MB/s 1:04:09 7,171,658,432 32% 3.77MB/s 1:04:10 7,175,623,360 32% 3.78MB/s 1:04:08 7,179,522,752 32% 3.76MB/s 1:04:23 7,183,520,448 32% 3.76MB/s 1:04:19 7,187,485,376 32% 3.76MB/s 1:04:18 7,191,483,072 32% 3.77MB/s 1:04:13 7,195,415,232 32% 3.78MB/s 1:04:03 7,199,412,928 32% 3.77MB/s 1:04:05 7,203,377,856 32% 3.78MB/s 1:04:01 7,207,310,016 32% 3.76MB/s 1:04:14 7,211,242,176 32% 3.76MB/s 1:04:18 7,215,207,104 32% 3.76MB/s 1:04:19 7,219,172,032 32% 3.75MB/s 1:04:21 7,223,136,960 32% 3.76MB/s 1:04:10 7,227,101,888 32% 3.77MB/s 1:03:56 7,231,066,816 32% 3.78MB/s 1:03:53 7,234,998,976 32% 3.76MB/s 1:04:05 7,238,963,904 32% 3.77MB/s 1:04:02 7,242,928,832 32% 3.77MB/s 1:04:00 7,246,893,760 32% 3.76MB/s 1:04:01 7,250,825,920 32% 3.77MB/s 1:03:56 7,254,823,616 32% 3.78MB/s 1:03:45 7,258,788,544 32% 3.77MB/s 1:03:49 7,262,687,936 32% 3.76MB/s 1:04:02 7,266,652,864 32% 3.77MB/s 1:03:54 7,270,617,792 32% 3.76MB/s 1:04:00 7,274,615,488 32% 3.77MB/s 1:03:52 7,278,580,416 33% 3.78MB/s 1:03:40 7,282,578,112 33% 3.78MB/s 1:03:35 7,286,543,040 33% 3.78MB/s 1:03:36 7,290,442,432 33% 3.76MB/s 1:03:55 7,294,440,128 33% 3.77MB/s 1:03:47 7,298,437,824 33% 3.77MB/s 1:03:47 7,302,402,752 33% 3.76MB/s 1:03:48 7,306,367,680 33% 3.78MB/s 1:03:33 7,310,332,608 33% 3.77MB/s 1:03:36 7,314,297,536 33% 3.77MB/s 1:03:38 7,318,229,696 33% 3.76MB/s 1:03:47 7,322,194,624 33% 3.76MB/s 1:03:45 7,326,192,320 33% 3.76MB/s 1:03:41 7,330,157,248 33% 3.77MB/s 1:03:38 7,334,122,176 33% 3.78MB/s 1:03:27 7,338,087,104 33% 3.78MB/s 1:03:23 7,342,052,032 33% 3.78MB/s 1:03:22 7,345,951,424 33% 3.76MB/s 1:03:42 7,349,949,120 33% 3.76MB/s 1:03:34 7,353,914,048 33% 3.76MB/s 1:03:34 7,357,878,976 33% 3.76MB/s 1:03:32 7,361,843,904 33% 3.79MB/s 1:03:10 7,365,808,832 33% 3.78MB/s 1:03:13 7,369,806,528 33% 3.79MB/s 1:03:07 7,373,705,920 33% 3.77MB/s 1:03:24 7,377,670,848 33% 3.77MB/s 1:03:25 7,381,635,776 33% 3.76MB/s 1:03:27 7,385,600,704 33% 3.76MB/s 1:03:33 7,389,565,632 33% 3.77MB/s 1:03:16 7,393,530,560 33% 3.77MB/s 1:03:14 7,397,528,256 33% 3.78MB/s 1:03:08 7,401,427,648 33% 3.77MB/s 1:03:20 7,405,392,576 33% 3.76MB/s 1:03:19 7,409,390,272 33% 3.77MB/s 1:03:15 7,413,355,200 33% 3.76MB/s 1:03:22 7,417,320,128 33% 3.77MB/s 1:03:10 7,421,317,824 33% 3.77MB/s 1:03:06 7,425,315,520 33% 3.78MB/s 1:03:02 7,429,280,448 33% 3.78MB/s 1:03:02 7,433,245,376 33% 3.78MB/s 1:02:55 7,437,243,072 33% 3.78MB/s 1:02:52 7,441,175,232 33% 3.77MB/s 1:03:03 7,445,140,160 33% 3.78MB/s 1:02:55 7,449,072,320 33% 3.76MB/s 1:03:08 7,453,037,248 33% 3.76MB/s 1:03:15 7,456,969,408 33% 3.75MB/s 1:03:17 7,460,967,104 33% 3.76MB/s 1:03:09 7,464,964,800 33% 3.78MB/s 1:02:52 7,468,962,496 33% 3.78MB/s 1:02:46 7,472,960,192 33% 3.80MB/s 1:02:25 7,476,925,120 33% 3.79MB/s 1:02:34 7,480,922,816 33% 3.79MB/s 1:02:34 7,484,822,208 33% 3.77MB/s 1:02:50 7,488,787,136 33% 3.76MB/s 1:02:59 7,492,784,832 33% 3.77MB/s 1:02:54 7,496,782,528 33% 3.77MB/s 1:02:52 7,500,747,456 34% 3.78MB/s 1:02:37 7,504,712,384 34% 3.78MB/s 1:02:42 7,508,710,080 34% 3.78MB/s 1:02:38 7,512,642,240 34% 3.76MB/s 1:02:52 7,516,639,936 34% 3.77MB/s 1:02:47 7,520,604,864 34% 3.77MB/s 1:02:41 7,524,569,792 34% 3.77MB/s 1:02:44 7,528,567,488 34% 3.78MB/s 1:02:29 7,532,532,416 34% 3.78MB/s 1:02:33 7,536,530,112 34% 3.78MB/s 1:02:27 7,540,462,272 34% 3.77MB/s 1:02:39 7,544,394,432 34% 3.76MB/s 1:02:53 7,548,392,128 34% 3.76MB/s 1:02:45 7,552,357,056 34% 3.76MB/s 1:02:48 7,556,354,752 34% 3.77MB/s 1:02:31 7,560,319,680 34% 3.78MB/s 1:02:20 7,564,284,608 34% 3.78MB/s 1:02:23 7,568,216,768 34% 3.77MB/s 1:02:28 7,572,181,696 34% 3.77MB/s 1:02:30 7,576,146,624 34% 3.77MB/s 1:02:31 7,580,111,552 34% 3.77MB/s 1:02:31 7,584,076,480 34% 3.77MB/s 1:02:25 7,588,041,408 34% 3.77MB/s 1:02:24 7,592,039,104 34% 3.78MB/s 1:02:17 7,595,938,496 34% 3.76MB/s 1:02:30 7,599,903,424 34% 3.77MB/s 1:02:27 7,603,868,352 34% 3.76MB/s 1:02:28 7,607,833,280 34% 3.76MB/s 1:02:37 7,611,830,976 34% 3.77MB/s 1:02:18 7,615,795,904 34% 3.78MB/s 1:02:14 7,619,793,600 34% 3.78MB/s 1:02:11 7,623,725,760 34% 3.78MB/s 1:02:11 7,627,723,456 34% 3.78MB/s 1:02:10 7,631,721,152 34% 3.78MB/s 1:02:09 7,635,686,080 34% 3.78MB/s 1:02:08 7,639,683,776 34% 3.79MB/s 1:01:57 7,643,648,704 34% 3.78MB/s 1:02:01 7,647,613,632 34% 3.78MB/s 1:02:03 7,651,545,792 34% 3.77MB/s 1:02:15 7,655,510,720 34% 3.76MB/s 1:02:16 7,659,475,648 34% 3.76MB/s 1:02:14 7,663,440,576 34% 3.76MB/s 1:02:13 7,667,405,504 34% 3.77MB/s 1:02:06 7,671,370,432 34% 3.77MB/s 1:02:07 7,675,335,360 34% 3.77MB/s 1:02:05 7,679,234,752 34% 3.76MB/s 1:02:16 7,683,232,448 34% 3.77MB/s 1:02:06 7,687,164,608 34% 3.76MB/s 1:02:13 7,691,129,536 34% 3.76MB/s 1:02:14 7,695,094,464 34% 3.77MB/s 1:01:58 7,699,059,392 34% 3.77MB/s 1:02:00 7,703,024,320 34% 3.78MB/s 1:01:52 7,706,956,480 34% 3.77MB/s 1:01:59 7,710,921,408 34% 3.76MB/s 1:02:00
7,714,886,336 34% 3.77MB/s 1:01:58 7,718,884,032 34% 3.77MB/s 1:01:54 7,722,881,728 35% 3.78MB/s 1:01:38 7,726,846,656 35% 3.79MB/s 1:01:34 7,730,811,584 35% 3.79MB/s 1:01:34 7,734,743,744 35% 3.77MB/s 1:01:46 7,738,741,440 35% 3.77MB/s 1:01:49 7,742,706,368 35% 3.77MB/s 1:01:52 7,746,671,296 35% 3.77MB/s 1:01:51 7,750,636,224 35% 3.78MB/s 1:01:37 7,754,633,920 35% 3.78MB/s 1:01:36 7,758,598,848 35% 3.78MB/s 1:01:32 7,762,531,008 35% 3.77MB/s 1:01:39 7,766,528,704 35% 3.78MB/s 1:01:31 7,770,526,400 35% 3.78MB/s 1:01:28 7,774,491,328 35% 3.78MB/s 1:01:27 7,778,456,256 35% 3.79MB/s 1:01:16 7,782,421,184 35% 3.78MB/s 1:01:28 7,786,386,112 35% 3.77MB/s 1:01:32 7,790,318,272 35% 3.76MB/s 1:01:43 7,794,315,968 35% 3.76MB/s 1:01:41 7,798,280,896 35% 3.76MB/s 1:01:38 7,802,278,592 35% 3.77MB/s 1:01:34 7,806,243,520 35% 3.78MB/s 1:01:23 7,810,208,448 35% 3.77MB/s 1:01:27 7,814,173,376 35% 3.78MB/s 1:01:22 7,818,105,536 35% 3.76MB/s 1:01:33 7,822,070,464 35% 3.76MB/s 1:01:36 7,826,068,160 35% 3.77MB/s 1:01:29 7,830,065,856 35% 3.77MB/s 1:01:27 7,834,030,784 35% 3.78MB/s 1:01:16 7,837,995,712 35% 3.78MB/s 1:01:11 7,841,993,408 35% 3.78MB/s 1:01:07 7,845,925,568 35% 3.77MB/s 1:01:20 7,849,923,264 35% 3.77MB/s 1:01:17 7,853,888,192 35% 3.77MB/s 1:01:17 7,857,885,888 35% 3.77MB/s 1:01:18 7,861,850,816 35% 3.78MB/s 1:01:04 7,865,815,744 35% 3.78MB/s 1:01:06 7,869,780,672 35% 3.78MB/s 1:01:08 7,873,712,832 35% 3.76MB/s 1:01:22 7,877,710,528 35% 3.76MB/s 1:01:18 7,881,675,456 35% 3.76MB/s 1:01:18 7,885,640,384 35% 3.77MB/s 1:01:14 7,889,605,312 35% 3.78MB/s 1:01:01 7,893,603,008 35% 3.78MB/s 1:00:59 7,897,567,936 35% 3.78MB/s 1:00:55 7,901,500,096 35% 3.77MB/s 1:01:04 7,905,497,792 35% 3.78MB/s 1:00:59 7,909,397,184 35% 3.76MB/s 1:01:16 7,913,362,112 35% 3.76MB/s 1:01:17 7,917,327,040 35% 3.77MB/s 1:01:05 7,921,291,968 35% 3.76MB/s 1:01:11 7,925,224,128 35% 3.77MB/s 1:01:02 7,929,156,288 35% 3.76MB/s 1:01:13 7,933,121,216 35% 3.76MB/s 1:01:12 7,937,118,912 35% 3.76MB/s 1:01:03 7,941,116,608 36% 3.78MB/s 1:00:50 7,945,114,304 36% 3.79MB/s 1:00:35 7,949,112,000 36% 3.80MB/s 1:00:28 7,953,109,696 36% 3.79MB/s 1:00:30 7,957,009,088 36% 3.77MB/s 1:00:49 7,960,974,016 36% 3.77MB/s 1:00:50 7,964,938,944 36% 3.76MB/s 1:00:56 7,968,936,640 36% 3.76MB/s 1:00:53 7,972,901,568 36% 3.78MB/s 1:00:39 7,976,899,264 36% 3.78MB/s 1:00:35 7,980,896,960 36% 3.79MB/s 1:00:29 7,984,829,120 36% 3.77MB/s 1:00:40 7,988,826,816 36% 3.78MB/s 1:00:33 7,992,824,512 36% 3.78MB/s 1:00:31 7,996,789,440 36% 3.78MB/s 1:00:32 8,000,787,136 36% 3.79MB/s 1:00:19 8,004,752,064 36% 3.79MB/s 1:00:24 8,008,716,992 36% 3.78MB/s 1:00:27 8,012,649,152 36% 3.77MB/s 1:00:39 8,016,614,080 36% 3.76MB/s 1:00:44 8,020,480,704 36% 3.74MB/s 1:01:03 8,024,445,632 36% 3.74MB/s 1:01:02 8,028,410,560 36% 3.75MB/s 1:00:49 8,032,375,488 36% 3.75MB/s 1:00:46 8,036,340,416 36% 3.77MB/s 1:00:26 8,040,239,808 36% 3.76MB/s 1:00:41 8,044,204,736 36% 3.75MB/s 1:00:45 8,048,169,664 36% 3.76MB/s 1:00:42 8,052,134,592 36% 3.76MB/s 1:00:37 8,056,099,520 36% 3.77MB/s 1:00:24 8,060,097,216 36% 3.78MB/s 1:00:14 8,064,062,144 36% 3.78MB/s 1:00:17 8,067,994,304 36% 3.77MB/s 1:00:27 8,071,959,232 36% 3.77MB/s 1:00:26 8,075,924,160 36% 3.76MB/s 1:00:28 8,079,921,856 36% 3.77MB/s 1:00:22 8,083,821,248 36% 3.76MB/s 1:00:23 8,087,786,176 36% 3.77MB/s 1:00:21 8,091,751,104 36% 3.77MB/s 1:00:20 8,095,683,264 36% 3.75MB/s 1:00:30 8,099,648,192 36% 3.77MB/s 1:00:16 8,103,645,888 36% 3.77MB/s 1:00:12 8,107,643,584 36% 3.77MB/s 1:00:10 8,111,641,280 36% 3.79MB/s 0:59:55 8,115,606,208 36% 3.79MB/s 0:59:54 8,119,571,136 36% 3.78MB/s 0:59:55 8,123,503,296 36% 3.77MB/s 1:00:05 8,127,500,992 36% 3.77MB/s 1:00:04 8,131,465,920 36% 3.77MB/s 1:00:05 8,135,463,616 36% 3.78MB/s 1:00:00 8,139,395,776 36% 3.78MB/s 0:59:57 8,143,393,472 36% 3.78MB/s 0:59:57 8,147,358,400 36% 3.78MB/s 0:59:54 8,151,257,792 36% 3.76MB/s 1:00:13 8,155,222,720 36% 3.76MB/s 1:00:09 8,159,154,880 36% 3.74MB/s 1:00:23 8,163,119,808 37% 3.74MB/s 1:00:26 8,167,084,736 37% 3.75MB/s 1:00:13 8,171,049,664 37% 3.76MB/s 1:00:06 8,175,014,592 37% 3.77MB/s 0:59:51 8,178,913,984 37% 3.76MB/s 1:00:02 8,182,878,912 37% 3.77MB/s 0:59:57 8,186,843,840 37% 3.77MB/s 0:59:56 8,190,808,768 37% 3.76MB/s 0:59:59 8,194,806,464 37% 3.78MB/s 0:59:42 8,198,804,160 37% 3.78MB/s 0:59:39 8,202,769,088 37% 3.78MB/s 0:59:38 8,206,734,016 37% 3.78MB/s 0:59:37 8,210,698,944 37% 3.78MB/s 0:59:38 8,214,696,640 37% 3.78MB/s 0:59:37 8,218,628,800 37% 3.77MB/s 0:59:46 8,222,593,728 37% 3.78MB/s 0:59:37 8,226,558,656 37% 3.77MB/s 0:59:37 8,230,523,584 37% 3.77MB/s 0:59:45 8,234,455,744 37% 3.77MB/s 0:59:43 8,238,420,672 37% 3.76MB/s 0:59:43 8,242,385,600 37% 3.76MB/s 0:59:44 8,246,350,528 37% 3.77MB/s 0:59:37 8,250,315,456 37% 3.78MB/s 0:59:28 8,254,280,384 37% 3.78MB/s 0:59:26 8,258,245,312 37% 3.78MB/s 0:59:28 8,262,177,472 37% 3.76MB/s 0:59:38 8,266,142,400 37% 3.76MB/s 0:59:41 8,270,107,328 37% 3.76MB/s 0:59:39 8,274,105,024 37% 3.77MB/s 0:59:34 8,278,102,720 37% 3.78MB/s 0:59:20 8,282,100,416 37% 3.79MB/s 0:59:12 8,286,032,576 37% 3.78MB/s 0:59:18 8,289,997,504 37% 3.78MB/s 0:59:17 8,293,962,432 37% 3.78MB/s 0:59:18 8,297,927,360 37% 3.77MB/s 0:59:23 8,301,892,288 37% 3.78MB/s 0:59:14 8,305,889,984 37% 3.78MB/s 0:59:09 8,309,887,680 37% 3.79MB/s 0:59:05 8,313,787,072 37% 3.77MB/s 0:59:17 8,317,752,000 37% 3.77MB/s 0:59:17 8,321,716,928 37% 3.77MB/s 0:59:19 8,325,681,856 37% 3.76MB/s 0:59:24 8,329,646,784 37% 3.78MB/s 0:59:09 8,333,611,712 37% 3.77MB/s 0:59:10 8,337,576,640 37% 3.77MB/s 0:59:14 8,341,476,032 37% 3.76MB/s 0:59:25 8,345,440,960 37% 3.75MB/s 0:59:27 8,349,438,656 37% 3.76MB/s 0:59:17 8,353,403,584 37% 3.76MB/s 0:59:14 8,357,368,512 37% 3.78MB/s 0:59:00 8,361,333,440 37% 3.78MB/s 0:58:56 8,365,298,368 37% 3.78MB/s 0:59:00 8,369,230,528 37% 3.77MB/s 0:59:09 8,373,195,456 37% 3.77MB/s 0:59:08 8,377,160,384 37% 3.76MB/s 0:59:08 8,381,125,312 38% 3.76MB/s 0:59:13 8,385,090,240 38% 3.77MB/s 0:59:04 8,389,055,168 38% 3.77MB/s 0:59:04 8,393,020,096 38% 3.76MB/s 0:59:05 8,396,853,952 38% 3.74MB/s 0:59:27 8,400,818,880 38% 3.74MB/s 0:59:27 8,404,783,808 38% 3.74MB/s 0:59:23 8,408,748,736 38% 3.75MB/s 0:59:17 8,412,713,664 38% 3.77MB/s 0:58:49 8,416,711,360 38% 3.78MB/s 0:58:40 8,420,676,288 38% 3.79MB/s 0:58:36 8,424,608,448 38% 3.77MB/s 0:58:48 8,428,606,144 38% 3.78MB/s 0:58:41 8,432,571,072 38% 3.77MB/s 0:58:46 8,436,536,000 38% 3.77MB/s 0:58:49 8,440,500,928 38% 3.78MB/s 0:58:40 8,444,465,856 38% 3.77MB/s 0:58:43 8,448,463,552 38% 3.77MB/s 0:58:40 8,452,362,944 38% 3.76MB/s 0:58:57 8,456,327,872 38% 3.76MB/s 0:58:52 8,460,260,032 38% 3.75MB/s 0:59:02 8,464,224,960 38% 3.75MB/s 0:59:01 8,468,189,888 38% 3.77MB/s 0:58:41 8,472,187,584 38% 3.77MB/s 0:58:37 8,476,152,512 38% 3.78MB/s 0:58:25 8,480,084,672 38% 3.77MB/s 0:58:36 8,484,049,600 38% 3.77MB/s 0:58:38 8,488,014,528 38% 3.76MB/s 0:58:39 8,492,012,224 38% 3.77MB/s 0:58:34 8,495,911,616 38% 3.76MB/s 0:58:37 8,499,876,544 38% 3.76MB/s 0:58:36 8,503,841,472 38% 3.76MB/s 0:58:38 8,507,740,864 38% 3.74MB/s 0:58:55 8,511,738,560 38% 3.76MB/s 0:58:35 8,515,736,256 38% 3.77MB/s 0:58:27 8,519,701,184 38% 3.77MB/s 0:58:26 8,523,666,112 38% 3.78MB/s 0:58:12 8,527,663,808 38% 3.78MB/s 0:58:11 8,531,628,736 38% 3.78MB/s 0:58:15 8,535,560,896 38% 3.77MB/s 0:58:24 8,539,525,824 38% 3.76MB/s 0:58:27 8,543,490,752 38% 3.76MB/s 0:58:29 8,547,455,680 38% 3.76MB/s 0:58:29 8,551,420,608 38% 3.77MB/s 0:58:15 8,555,385,536 38% 3.78MB/s 0:58:10 8,559,350,464 38% 3.78MB/s 0:58:07 8,563,249,856 38% 3.76MB/s 0:58:19 8,567,214,784 38% 3.76MB/s 0:58:20 8,571,212,480 38% 3.76MB/s 0:58:18 8,575,177,408 38% 3.76MB/s 0:58:17 8,579,175,104 38% 3.78MB/s 0:57:57 8,583,172,800 38% 3.79MB/s 0:57:51 8,587,137,728 38% 3.79MB/s 0:57:52 8,591,069,888 38% 3.77MB/s 0:58:04 8,595,034,816 38% 3.77MB/s 0:58:08 8,599,032,512 38% 3.77MB/s 0:58:07 8,602,997,440 39% 3.77MB/s 0:58:04 8,606,962,368 39% 3.78MB/s 0:57:53 8,610,894,528 39% 3.77MB/s 0:58:00 8,614,859,456 39% 3.77MB/s 0:58:02 8,618,758,848 39% 3.75MB/s 0:58:16 8,622,723,776 39% 3.75MB/s 0:58:13 8,626,721,472 39% 3.77MB/s 0:57:59 8,630,686,400 39% 3.77MB/s 0:57:59 8,634,618,560 39% 3.77MB/s 0:57:55 8,638,583,488 39% 3.77MB/s 0:57:55 8,642,548,416 39% 3.76MB/s 0:57:59 8,646,447,808 39% 3.75MB/s 0:58:12 8,650,412,736 39% 3.76MB/s 0:58:02 8,654,377,664 39% 3.76MB/s 0:58:01 8,658,342,592 39% 3.76MB/s 0:58:00 8,662,340,288 39% 3.78MB/s 0:57:42 8,666,337,984 39% 3.78MB/s 0:57:37 8,670,335,680 39% 3.79MB/s 0:57:29 8,674,267,840 39% 3.78MB/s 0:57:32 8,678,265,536 39% 3.79MB/s 0:57:29 8,682,230,464 39% 3.78MB/s 0:57:32 8,686,195,392 39% 3.78MB/s 0:57:37 8,690,160,320 39% 3.78MB/s 0:57:29 8,694,125,248 39% 3.78MB/s 0:57:34 8,698,122,944 39% 3.78MB/s 0:57:27 8,702,055,104 39% 3.77MB/s 0:57:34 8,706,052,800 39% 3.78MB/s 0:57:24 8,710,050,496 39% 3.79MB/s 0:57:18 8,714,048,192 39% 3.79MB/s 0:57:19 8,718,045,888 39% 3.80MB/s 0:57:06 8,722,010,816 39% 3.79MB/s 0:57:13 8,726,008,512 39% 3.80MB/s 0:57:09 8,729,907,904 39% 3.78MB/s 0:57:24 8,733,807,296 39% 3.76MB/s 0:57:41 8,737,739,456 39% 3.75MB/s 0:57:46 8,741,704,384 39% 3.74MB/s 0:57:51 8,745,669,312 39% 3.76MB/s 0:57:39 8,749,634,240 39% 3.77MB/s 0:57:24 8,753,599,168 39% 3.78MB/s 0:57:17 8,757,531,328 39% 3.77MB/s 0:57:27 8,761,529,024 39% 3.77MB/s 0:57:21 8,765,526,720 39% 3.77MB/s 0:57:18 8,769,524,416 39% 3.78MB/s 0:57:13 8,773,489,344 39% 3.79MB/s 0:57:02 8,777,454,272 39% 3.79MB/s 0:57:03 8,781,451,968 39% 3.79MB/s 0:56:59 8,785,384,128 39% 3.78MB/s 0:57:11 8,789,349,056 39% 3.77MB/s 0:57:15 8,793,313,984 39% 3.77MB/s 0:57:16 8,797,278,912 39% 3.76MB/s 0:57:20 8,801,243,840 39% 3.77MB/s 0:57:09 8,805,208,768 39% 3.78MB/s 0:57:04 8,809,173,696 39% 3.78MB/s 0:57:05 8,813,073,088 39% 3.76MB/s 0:57:18 8,817,070,784 39% 3.77MB/s 0:57:12 8,821,035,712 39% 3.76MB/s 0:57:14 8,824,967,872 40% 3.76MB/s 0:57:16 8,828,932,800 40% 3.77MB/s 0:57:01 8,832,897,728 40% 3.77MB/s 0:57:05 8,836,862,656 40% 3.77MB/s 0:57:00 8,840,794,816 40% 3.77MB/s 0:57:05 8,844,759,744 40% 3.77MB/s 0:57:04 8,848,757,440 40% 3.77MB/s 0:57:00 8,852,755,136 40% 3.77MB/s 0:56:55 8,856,720,064 40% 3.78MB/s 0:56:45 8,860,717,760 40% 3.79MB/s 0:56:41 8,864,715,456 40% 3.79MB/s 0:56:42 8,868,614,848 40% 3.77MB/s 0:56:57 8,872,547,008 40% 3.76MB/s 0:57:04 8,876,511,936 40% 3.75MB/s 0:57:08 8,880,476,864 40% 3.75MB/s 0:57:08 8,884,441,792 40% 3.77MB/s 0:56:55 8,888,406,720 40% 3.77MB/s 0:56:46 8,892,371,648 40% 3.78MB/s 0:56:43 8,896,271,040 40% 3.76MB/s 0:56:57 8,900,268,736 40% 3.77MB/s 0:56:50 8,904,266,432 40% 3.77MB/s 0:56:44 8,908,231,360 40% 3.77MB/s 0:56:42 8,912,229,056 40% 3.79MB/s 0:56:25 8,916,193,984 40% 3.78MB/s 0:56:30 8,920,158,912 40% 3.78MB/s 0:56:34 8,924,091,072 40% 3.77MB/s 0:56:43 8,928,056,000 40% 3.77MB/s 0:56:44 8,932,020,928 40% 3.77MB/s 0:56:42 8,935,985,856 40% 3.77MB/s 0:56:42 8,939,983,552 40% 3.78MB/s 0:56:28 8,943,948,480 40% 3.78MB/s 0:56:27 8,947,913,408 40% 3.78MB/s 0:56:26 8,951,845,568 40% 3.77MB/s 0:56:33 8,955,843,264 40% 3.77MB/s 0:56:34 8,959,808,192 40% 3.77MB/s 0:56:34 8,963,805,888 40% 3.77MB/s 0:56:29 8,967,770,816 40% 3.79MB/s 0:56:16 8,971,702,976 40% 3.77MB/s 0:56:27 8,975,667,904 40% 3.77MB/s 0:56:25 8,979,567,296 40% 3.75MB/s 0:56:43 8,983,532,224 40% 3.75MB/s 0:56:42 8,987,497,152 40% 3.76MB/s 0:56:31 8,991,494,848 40% 3.77MB/s 0:56:26 8,995,459,776 40% 3.78MB/s 0:56:12 8,999,424,704 40% 3.78MB/s 0:56:15 9,003,422,400 40% 3.78MB/s 0:56:11 9,007,354,560 40% 3.77MB/s 0:56:24 9,011,319,488 40% 3.76MB/s 0:56:26 9,015,317,184 40% 3.77MB/s 0:56:20 9,019,282,112 40% 3.76MB/s 0:56:23 9,023,214,272 40% 3.77MB/s 0:56:19 9,027,179,200 40% 3.77MB/s 0:56:15 9,031,144,128 40% 3.77MB/s 0:56:17 9,035,076,288 40% 3.75MB/s 0:56:26 9,039,041,216 40% 3.76MB/s 0:56:18 9,043,038,912 41% 3.77MB/s 0:56:11 9,047,036,608 41% 3.77MB/s 0:56:06 9,051,034,304 41% 3.79MB/s 0:55:51 9,054,999,232 41% 3.79MB/s 0:55:51 9,058,996,928 41% 3.79MB/s 0:55:51 9,062,929,088 41% 3.77MB/s 0:56:05 9,066,926,784 41% 3.77MB/s 0:56:05 9,070,957,248 41% 3.78MB/s 0:55:53 9,074,922,176 41% 3.78MB/s 0:55:55 9,078,919,872 41% 3.79MB/s 0:55:40 9,082,917,568 41% 3.79MB/s 0:55:38 9,086,882,496 41% 3.78MB/s 0:55:47 9,090,781,888 41% 3.77MB/s 0:56:00 9,094,714,048 41% 3.76MB/s 0:56:09 9,098,646,208 41% 3.75MB/s 0:56:18 9,102,611,136 41% 3.74MB/s 0:56:21 9,106,608,832 41% 3.76MB/s 0:56:04 9,110,540,992 41% 3.76MB/s 0:56:02 9,114,505,920 41% 3.77MB/s 0:55:53 9,118,438,080 41% 3.76MB/s 0:55:56 9,122,403,008 41% 3.76MB/s 0:55:57 9,126,400,704 41% 3.77MB/s 0:55:45 9,130,365,632 41% 3.77MB/s 0:55:48 9,134,330,560 41% 3.78MB/s 0:55:37 9,138,295,488 41% 3.78MB/s 0:55:35 9,142,293,184 41% 3.78MB/s 0:55:33 9,146,192,576 41% 3.77MB/s 0:55:43 9,150,157,504 41% 3.77MB/s 0:55:43 9,154,122,432 41% 3.77MB/s 0:55:45 9,157,989,056 41% 3.74MB/s 0:56:08 9,161,953,984 41% 3.75MB/s 0:55:54 9,165,918,912 41% 3.75MB/s 0:55:52 9,169,883,840 41% 3.76MB/s 0:55:49 9,173,783,232 41% 3.76MB/s 0:55:48 9,177,780,928 41% 3.76MB/s 0:55:42 9,181,745,856 41% 3.76MB/s 0:55:40 9,185,710,784 41% 3.76MB/s 0:55:41 9,189,675,712 41% 3.78MB/s 0:55:23 9,193,640,640 41% 3.77MB/s 0:55:28
9,197,605,568 41% 3.77MB/s 0:55:30 9,201,537,728 41% 3.76MB/s 0:55:34 9,205,469,888 41% 3.76MB/s 0:55:36 9,209,434,816 41% 3.76MB/s 0:55:37 9,213,399,744 41% 3.76MB/s 0:55:34 9,217,364,672 41% 3.77MB/s 0:55:29 9,221,329,600 41% 3.77MB/s 0:55:24 9,225,294,528 41% 3.77MB/s 0:55:24 9,229,193,920 41% 3.75MB/s 0:55:36 9,233,158,848 41% 3.76MB/s 0:55:32 9,237,123,776 41% 3.76MB/s 0:55:30 9,241,088,704 41% 3.76MB/s 0:55:29 9,245,086,400 41% 3.78MB/s 0:55:13 9,249,051,328 41% 3.77MB/s 0:55:13 9,253,016,256 41% 3.77MB/s 0:55:12 9,256,915,648 41% 3.76MB/s 0:55:20 9,260,880,576 41% 3.76MB/s 0:55:23 9,264,845,504 42% 3.76MB/s 0:55:22 9,268,810,432 42% 3.76MB/s 0:55:23 9,272,775,360 42% 3.77MB/s 0:55:11 9,276,773,056 42% 3.78MB/s 0:55:03 9,280,737,984 42% 3.78MB/s 0:55:01 9,284,702,912 42% 3.77MB/s 0:55:03 9,288,667,840 42% 3.77MB/s 0:55:02 9,292,665,536 42% 3.77MB/s 0:55:03 9,296,630,464 42% 3.77MB/s 0:55:03 9,300,595,392 42% 3.78MB/s 0:54:55 9,304,560,320 42% 3.78MB/s 0:54:53 9,308,525,248 42% 3.78MB/s 0:54:54 9,312,457,408 42% 3.77MB/s 0:55:03 9,316,389,568 42% 3.76MB/s 0:55:09 9,320,354,496 42% 3.76MB/s 0:55:10 9,324,319,424 42% 3.75MB/s 0:55:12 9,328,284,352 42% 3.76MB/s 0:55:05 9,332,249,280 42% 3.76MB/s 0:55:01 9,336,214,208 42% 3.76MB/s 0:55:00 9,340,113,600 42% 3.75MB/s 0:55:14 9,344,111,296 42% 3.76MB/s 0:55:05 9,348,010,688 42% 3.74MB/s 0:55:19 9,352,008,384 42% 3.74MB/s 0:55:13 9,355,973,312 42% 3.76MB/s 0:54:58 9,359,971,008 42% 3.76MB/s 0:54:57 9,363,935,936 42% 3.78MB/s 0:54:38 9,367,835,328 42% 3.76MB/s 0:54:53 9,371,800,256 42% 3.76MB/s 0:54:53 9,375,765,184 42% 3.76MB/s 0:54:55 9,379,730,112 42% 3.76MB/s 0:54:53 9,383,695,040 42% 3.77MB/s 0:54:38 9,387,659,968 42% 3.78MB/s 0:54:34 9,391,624,896 42% 3.78MB/s 0:54:30 9,395,557,056 42% 3.77MB/s 0:54:38 9,399,521,984 42% 3.77MB/s 0:54:37 9,403,486,912 42% 3.76MB/s 0:54:41 9,407,451,840 42% 3.76MB/s 0:54:41 9,411,449,536 42% 3.78MB/s 0:54:29 9,415,414,464 42% 3.77MB/s 0:54:29 9,419,412,160 42% 3.78MB/s 0:54:22 9,423,344,320 42% 3.77MB/s 0:54:31 9,427,309,248 42% 3.77MB/s 0:54:31 9,431,274,176 42% 3.77MB/s 0:54:28 9,435,239,104 42% 3.76MB/s 0:54:33 9,439,204,032 42% 3.78MB/s 0:54:22 9,443,201,728 42% 3.78MB/s 0:54:20 9,447,133,888 42% 3.77MB/s 0:54:23 9,451,066,048 42% 3.76MB/s 0:54:30 9,455,030,976 42% 3.76MB/s 0:54:28 9,458,995,904 42% 3.76MB/s 0:54:30 9,462,960,832 42% 3.77MB/s 0:54:23 9,466,925,760 42% 3.78MB/s 0:54:14 9,470,923,456 42% 3.78MB/s 0:54:11 9,474,888,384 42% 3.78MB/s 0:54:08 9,478,820,544 42% 3.77MB/s 0:54:16 9,482,785,472 42% 3.77MB/s 0:54:14 9,486,750,400 43% 3.76MB/s 0:54:20 9,490,715,328 43% 3.76MB/s 0:54:22 9,494,713,024 43% 3.77MB/s 0:54:11 9,498,710,720 43% 3.78MB/s 0:54:02 9,502,675,648 43% 3.79MB/s 0:53:56 9,506,607,808 43% 3.78MB/s 0:54:03 9,510,605,504 43% 3.78MB/s 0:54:03 9,514,570,432 43% 3.77MB/s 0:54:07 9,518,568,128 43% 3.77MB/s 0:54:04 9,522,533,056 43% 3.79MB/s 0:53:52 9,526,530,752 43% 3.79MB/s 0:53:48 9,530,528,448 43% 3.80MB/s 0:53:42 9,534,427,840 43% 3.78MB/s 0:53:58 9,538,392,768 43% 3.77MB/s 0:54:03 9,542,390,464 43% 3.77MB/s 0:54:04 9,546,388,160 43% 3.76MB/s 0:54:05 9,550,353,088 43% 3.78MB/s 0:53:50 9,554,350,784 43% 3.79MB/s 0:53:40 9,558,348,480 43% 3.80MB/s 0:53:34 9,562,313,408 43% 3.79MB/s 0:53:40 9,566,311,104 43% 3.79MB/s 0:53:36 9,570,308,800 43% 3.79MB/s 0:53:38 9,574,306,496 43% 3.78MB/s 0:53:41 9,578,304,192 43% 3.79MB/s 0:53:35 9,582,236,352 43% 3.78MB/s 0:53:42 9,586,201,280 43% 3.78MB/s 0:53:44 9,590,133,440 43% 3.76MB/s 0:53:55 9,594,131,136 43% 3.76MB/s 0:53:54 9,598,128,832 43% 3.77MB/s 0:53:46 9,602,126,528 43% 3.78MB/s 0:53:41 9,606,124,224 43% 3.79MB/s 0:53:26 9,610,089,152 43% 3.78MB/s 0:53:31 9,614,086,848 43% 3.79MB/s 0:53:29 9,618,019,008 43% 3.77MB/s 0:53:40 9,621,983,936 43% 3.76MB/s 0:53:47 9,625,981,632 43% 3.77MB/s 0:53:35 9,629,946,560 43% 3.77MB/s 0:53:36 9,633,944,256 43% 3.79MB/s 0:53:24 9,637,941,952 43% 3.79MB/s 0:53:18 9,641,906,880 43% 3.78MB/s 0:53:28 9,645,839,040 43% 3.77MB/s 0:53:35 9,649,836,736 43% 3.77MB/s 0:53:37 9,653,834,432 43% 3.77MB/s 0:53:35 9,657,799,360 43% 3.77MB/s 0:53:29 9,661,764,288 43% 3.78MB/s 0:53:21 9,665,729,216 43% 3.78MB/s 0:53:20 9,669,661,376 43% 3.77MB/s 0:53:31 9,673,659,072 43% 3.77MB/s 0:53:25 9,677,624,000 43% 3.77MB/s 0:53:25 9,681,588,928 43% 3.77MB/s 0:53:22 9,685,586,624 43% 3.79MB/s 0:53:11 9,689,551,552 43% 3.78MB/s 0:53:14 9,693,483,712 43% 3.77MB/s 0:53:22 9,697,415,872 43% 3.76MB/s 0:53:31 9,701,380,800 43% 3.76MB/s 0:53:31 9,705,345,728 44% 3.76MB/s 0:53:30 9,709,310,656 44% 3.77MB/s 0:53:19 9,713,275,584 44% 3.78MB/s 0:53:08 9,717,240,512 44% 3.78MB/s 0:53:08 9,721,205,440 44% 3.78MB/s 0:53:07 9,725,137,600 44% 3.77MB/s 0:53:16 9,729,102,528 44% 3.76MB/s 0:53:17 9,733,100,224 44% 3.77MB/s 0:53:14 9,737,065,152 44% 3.77MB/s 0:53:10 9,741,062,848 44% 3.78MB/s 0:52:57 9,745,027,776 44% 3.78MB/s 0:52:56 9,749,025,472 44% 3.79MB/s 0:52:54 9,752,990,400 44% 3.78MB/s 0:52:57 9,756,988,096 44% 3.78MB/s 0:52:56 9,760,953,024 44% 3.78MB/s 0:52:57 9,764,917,952 44% 3.77MB/s 0:53:04 9,768,882,880 44% 3.77MB/s 0:52:58 9,772,847,808 44% 3.77MB/s 0:53:02 9,776,812,736 44% 3.77MB/s 0:52:59 9,780,679,360 44% 3.75MB/s 0:53:14 9,784,677,056 44% 3.75MB/s 0:53:11 9,788,674,752 44% 3.76MB/s 0:53:05 9,792,672,448 44% 3.77MB/s 0:52:59 9,796,637,376 44% 3.79MB/s 0:52:39 9,800,602,304 44% 3.79MB/s 0:52:40 9,804,600,000 44% 3.78MB/s 0:52:41 9,808,532,160 44% 3.77MB/s 0:52:53 9,812,464,320 44% 3.76MB/s 0:52:58 9,816,429,248 44% 3.76MB/s 0:53:01 9,820,328,640 44% 3.74MB/s 0:53:15 9,824,326,336 44% 3.75MB/s 0:53:03 9,828,291,264 44% 3.76MB/s 0:52:55 9,832,256,192 44% 3.77MB/s 0:52:49 9,836,188,352 44% 3.77MB/s 0:52:43 9,840,153,280 44% 3.77MB/s 0:52:46 9,844,118,208 44% 3.77MB/s 0:52:44 9,848,083,136 44% 3.77MB/s 0:52:44 9,852,080,832 44% 3.78MB/s 0:52:33 9,856,045,760 44% 3.78MB/s 0:52:32 9,860,010,688 44% 3.77MB/s 0:52:34 9,863,942,848 44% 3.76MB/s 0:52:43 9,867,907,776 44% 3.76MB/s 0:52:44 9,871,839,936 44% 3.76MB/s 0:52:48 9,875,804,864 44% 3.76MB/s 0:52:43 9,879,769,792 44% 3.77MB/s 0:52:31 9,883,734,720 44% 3.77MB/s 0:52:30 9,887,699,648 44% 3.78MB/s 0:52:27 9,891,599,040 44% 3.76MB/s 0:52:39 9,895,596,736 44% 3.76MB/s 0:52:36 9,899,561,664 44% 3.76MB/s 0:52:36 9,903,559,360 44% 3.77MB/s 0:52:28 9,907,557,056 44% 3.79MB/s 0:52:12 9,911,554,752 44% 3.79MB/s 0:52:11 9,915,519,680 44% 3.79MB/s 0:52:09 9,919,419,072 44% 3.76MB/s 0:52:29 9,923,384,000 44% 3.76MB/s 0:52:30 9,927,348,928 45% 3.76MB/s 0:52:31 9,931,313,856 45% 3.76MB/s 0:52:32 9,935,278,784 45% 3.78MB/s 0:52:12 9,939,276,480 45% 3.78MB/s 0:52:10 9,943,241,408 45% 3.78MB/s 0:52:10 9,947,173,568 45% 3.77MB/s 0:52:14 9,951,171,264 45% 3.77MB/s 0:52:12 9,955,136,192 45% 3.77MB/s 0:52:16 9,959,101,120 45% 3.76MB/s 0:52:18 9,963,098,816 45% 3.78MB/s 0:52:05 9,967,096,512 45% 3.78MB/s 0:52:02 9,971,061,440 45% 3.79MB/s 0:51:57 9,974,993,600 45% 3.78MB/s 0:52:01 9,978,991,296 45% 3.78MB/s 0:52:00 9,982,988,992 45% 3.78MB/s 0:51:56 9,986,953,920 45% 3.78MB/s 0:51:55 9,990,951,616 45% 3.79MB/s 0:51:45 9,994,949,312 45% 3.79MB/s 0:51:44 9,998,947,008 45% 3.79MB/s 0:51:45 10,002,879,168 45% 3.79MB/s 0:51:49 10,006,876,864 45% 3.78MB/s 0:51:48 10,010,874,560 45% 3.78MB/s 0:51:50 10,014,872,256 45% 3.78MB/s 0:51:49 10,018,869,952 45% 3.79MB/s 0:51:38 10,022,867,648 45% 3.79MB/s 0:51:36 10,026,832,576 45% 3.79MB/s 0:51:37 10,030,764,736 45% 3.77MB/s 0:51:50 10,034,762,432 45% 3.77MB/s 0:51:52 10,038,760,128 45% 3.77MB/s 0:51:51 10,042,725,056 45% 3.77MB/s 0:51:53 10,046,689,984 45% 3.78MB/s 0:51:42 10,050,687,680 45% 3.78MB/s 0:51:41 10,054,685,376 45% 3.78MB/s 0:51:39 10,058,552,000 45% 3.76MB/s 0:51:57 10,062,549,696 45% 3.76MB/s 0:51:52 10,066,514,624 45% 3.76MB/s 0:51:51 10,070,512,320 45% 3.76MB/s 0:51:50 10,074,477,248 45% 3.79MB/s 0:51:29 10,078,442,176 45% 3.78MB/s 0:51:30 10,082,439,872 45% 3.79MB/s 0:51:24 10,086,404,800 45% 3.78MB/s 0:51:29 10,090,402,496 45% 3.79MB/s 0:51:25 10,094,400,192 45% 3.79MB/s 0:51:20 10,098,365,120 45% 3.78MB/s 0:51:26 10,102,362,816 45% 3.79MB/s 0:51:19 10,106,327,744 45% 3.79MB/s 0:51:21 10,110,292,672 45% 3.78MB/s 0:51:26 10,114,224,832 45% 3.77MB/s 0:51:33 10,118,189,760 45% 3.77MB/s 0:51:35 10,122,187,456 45% 3.77MB/s 0:51:28 10,126,185,152 45% 3.78MB/s 0:51:24 10,130,150,080 45% 3.78MB/s 0:51:17 10,134,115,008 45% 3.79MB/s 0:51:14 10,138,112,704 45% 3.78MB/s 0:51:18 10,142,044,864 45% 3.77MB/s 0:51:23 10,146,042,560 46% 3.78MB/s 0:51:18 10,150,040,256 46% 3.78MB/s 0:51:14 10,154,005,184 46% 3.78MB/s 0:51:16 10,157,970,112 46% 3.78MB/s 0:51:09 10,161,967,808 46% 3.78MB/s 0:51:08 10,165,932,736 46% 3.78MB/s 0:51:12 10,169,864,896 46% 3.77MB/s 0:51:16 10,173,895,360 46% 3.78MB/s 0:51:07 10,177,893,056 46% 3.79MB/s 0:51:04 10,181,890,752 46% 3.79MB/s 0:50:57 10,185,855,680 46% 3.80MB/s 0:50:49 10,189,853,376 46% 3.79MB/s 0:50:55 10,193,851,072 46% 3.79MB/s 0:50:54 10,197,750,464 46% 3.77MB/s 0:51:09 10,201,748,160 46% 3.77MB/s 0:51:07 10,205,745,856 46% 3.77MB/s 0:51:05 10,209,743,552 46% 3.78MB/s 0:51:02 10,213,741,248 46% 3.80MB/s 0:50:46 10,217,706,176 46% 3.79MB/s 0:50:50 10,221,703,872 46% 3.79MB/s 0:50:49 10,225,636,032 46% 3.77MB/s 0:51:03 10,229,633,728 46% 3.77MB/s 0:51:00 10,233,598,656 46% 3.78MB/s 0:50:57 10,237,563,584 46% 3.77MB/s 0:51:02 10,241,528,512 46% 3.78MB/s 0:50:50 10,245,493,440 46% 3.78MB/s 0:50:53 10,249,458,368 46% 3.78MB/s 0:50:51 10,253,390,528 46% 3.77MB/s 0:50:55 10,257,355,456 46% 3.77MB/s 0:50:57 10,261,353,152 46% 3.77MB/s 0:50:53 10,265,350,848 46% 3.77MB/s 0:50:50 10,269,283,008 46% 3.78MB/s 0:50:48 10,273,280,704 46% 3.78MB/s 0:50:42 10,277,245,632 46% 3.77MB/s 0:50:46 10,281,112,256 46% 3.75MB/s 0:51:05 10,285,044,416 46% 3.75MB/s 0:51:07 10,289,009,344 46% 3.74MB/s 0:51:14 10,293,007,040 46% 3.75MB/s 0:51:04 10,296,971,968 46% 3.77MB/s 0:50:47 10,300,936,896 46% 3.78MB/s 0:50:37 10,304,901,824 46% 3.78MB/s 0:50:35 10,308,833,984 46% 3.76MB/s 0:50:49 10,312,798,912 46% 3.76MB/s 0:50:48 10,316,763,840 46% 3.76MB/s 0:50:51 10,320,761,536 46% 3.77MB/s 0:50:41 10,324,726,464 46% 3.78MB/s 0:50:30 10,328,691,392 46% 3.78MB/s 0:50:27 10,332,656,320 46% 3.79MB/s 0:50:22 10,336,555,712 46% 3.76MB/s 0:50:41 10,340,520,640 46% 3.76MB/s 0:50:40 10,344,518,336 46% 3.76MB/s 0:50:37 10,348,483,264 46% 3.76MB/s 0:50:38 10,352,480,960 46% 3.78MB/s 0:50:22 10,356,478,656 46% 3.78MB/s 0:50:18 10,360,443,584 46% 3.78MB/s 0:50:19 10,364,375,744 46% 3.77MB/s 0:50:25 10,368,340,672 47% 3.77MB/s 0:50:26 10,372,305,600 47% 3.77MB/s 0:50:28 10,376,303,296 47% 3.77MB/s 0:50:26 10,380,300,992 47% 3.78MB/s 0:50:15 10,384,298,688 47% 3.78MB/s 0:50:12 10,388,296,384 47% 3.79MB/s 0:50:07 10,392,228,544 47% 3.77MB/s 0:50:17 10,396,193,472 47% 3.77MB/s 0:50:21 10,400,191,168 47% 3.77MB/s 0:50:20 10,404,188,864 47% 3.77MB/s 0:50:19 10,408,153,792 47% 3.78MB/s 0:50:11 10,412,151,488 47% 3.79MB/s 0:50:03 10,416,116,416 47% 3.78MB/s 0:50:07 10,420,015,808 47% 3.76MB/s 0:50:22 10,424,013,504 47% 3.77MB/s 0:50:15 10,428,011,200 47% 3.77MB/s 0:50:14 10,432,008,896 47% 3.77MB/s 0:50:07 10,435,973,824 47% 3.79MB/s 0:49:52 10,439,971,520 47% 3.79MB/s 0:49:51 10,443,936,448 47% 3.79MB/s 0:49:52 10,447,868,608 47% 3.78MB/s 0:50:00 10,451,833,536 47% 3.78MB/s 0:50:00 10,455,831,232 47% 3.77MB/s 0:50:00 10,459,796,160 47% 3.77MB/s 0:50:02 10,463,793,856 47% 3.78MB/s 0:49:54 10,467,791,552 47% 3.79MB/s 0:49:47 10,471,789,248 47% 3.79MB/s 0:49:43 10,475,688,640 47% 3.78MB/s 0:49:51 10,479,653,568 47% 3.78MB/s 0:49:53 10,483,585,728 47% 3.76MB/s 0:50:03 10,487,583,424 47% 3.76MB/s 0:50:06 10,491,581,120 47% 3.77MB/s 0:49:51 10,495,546,048 47% 3.78MB/s 0:49:49 10,499,543,744 47% 3.79MB/s 0:49:40 10,503,475,904 47% 3.77MB/s 0:49:49 10,507,440,832 47% 3.77MB/s 0:49:49 10,511,405,760 47% 3.77MB/s 0:49:47 10,515,370,688 47% 3.77MB/s 0:49:48 10,519,368,384 47% 3.79MB/s 0:49:36 10,523,333,312 47% 3.78MB/s 0:49:35 10,527,298,240 47% 3.79MB/s 0:49:34 10,531,230,400 47% 3.77MB/s 0:49:42 10,535,162,560 47% 3.76MB/s 0:49:52 10,539,127,488 47% 3.76MB/s 0:49:53 10,543,125,184 47% 3.76MB/s 0:49:51 10,547,122,880 47% 3.77MB/s 0:49:38 10,551,120,576 47% 3.78MB/s 0:49:28 10,555,085,504 47% 3.79MB/s 0:49:26 10,558,984,896 47% 3.77MB/s 0:49:40 10,562,949,824 47% 3.76MB/s 0:49:40 10,566,881,984 47% 3.75MB/s 0:49:47 10,570,846,912 47% 3.76MB/s 0:49:44 10,574,811,840 47% 3.77MB/s 0:49:32 10,578,809,536 47% 3.77MB/s 0:49:29 10,582,807,232 47% 3.79MB/s 0:49:18 10,586,739,392 48% 3.77MB/s 0:49:28 10,590,704,320 48% 3.77MB/s 0:49:26 10,594,669,248 48% 3.77MB/s 0:49:28 10,598,634,176 48% 3.76MB/s 0:49:34 10,602,631,872 48% 3.78MB/s 0:49:19 10,606,596,800 48% 3.78MB/s 0:49:19 10,610,561,728 48% 3.78MB/s 0:49:16 10,614,493,888 48% 3.78MB/s 0:49:19 10,618,458,816 48% 3.77MB/s 0:49:23 10,622,456,512 48% 3.77MB/s 0:49:19 10,626,454,208 48% 3.78MB/s 0:49:15 10,630,451,904 48% 3.79MB/s 0:49:04 10,634,416,832 48% 3.79MB/s 0:49:02 10,638,381,760 48% 3.79MB/s 0:49:03 10,642,313,920 48% 3.78MB/s 0:49:10 10,646,311,616 48% 3.77MB/s 0:49:11 10,650,276,544 48% 3.78MB/s 0:49:08 10,654,241,472 48% 3.77MB/s 0:49:11 10,658,206,400 48% 3.78MB/s 0:49:05 10,662,204,096 48% 3.78MB/s 0:49:05 10,666,201,792 48% 3.78MB/s 0:49:02 10,670,133,952 48% 3.77MB/s 0:49:06 10,674,098,880 48% 3.78MB/s 0:49:03 10,678,063,808 48% 3.77MB/s 0:49:03 10,682,061,504 48% 3.78MB/s 0:49:00 10,686,059,200 48% 3.79MB/s 0:48:50 10,690,056,896 48% 3.79MB/s 0:48:47 10,694,054,592 48% 3.79MB/s 0:48:44 10,697,986,752 48% 3.78MB/s 0:48:57 10,701,984,448 48% 3.78MB/s 0:48:53 10,705,949,376 48% 3.78MB/s 0:48:54 10,709,914,304 48% 3.77MB/s 0:48:58 10,713,912,000 48% 3.79MB/s 0:48:45 10,717,909,696 48% 3.79MB/s 0:48:44 10,721,874,624 48% 3.79MB/s 0:48:43 10,725,806,784 48% 3.78MB/s 0:48:48 10,729,771,712 48% 3.78MB/s 0:48:49 10,733,736,640 48% 3.77MB/s 0:48:55 10,737,734,336 48% 3.77MB/s 0:48:50 10,741,699,264 48% 3.78MB/s 0:48:43 10,745,696,960 48% 3.78MB/s 0:48:39 10,749,694,656 48% 3.79MB/s 0:48:35 10,753,626,816 48% 3.77MB/s 0:48:46 10,757,624,512 48% 3.78MB/s 0:48:38 10,761,589,440 48% 3.78MB/s 0:48:38 10,765,554,368 48% 3.78MB/s 0:48:38 10,769,552,064 48% 3.79MB/s 0:48:27 10,773,516,992 48% 3.78MB/s 0:48:31 10,777,514,688 48% 3.79MB/s 0:48:28 10,781,446,848 48% 3.77MB/s 0:48:37 10,785,444,544 48% 3.77MB/s 0:48:35 10,789,442,240 48% 3.78MB/s 0:48:32 10,793,407,168 48% 3.77MB/s 0:48:33 10,797,404,864 48% 3.79MB/s 0:48:19 10,801,402,560 48% 3.79MB/s 0:48:18 10,805,334,720 48% 3.78MB/s 0:48:28 10,809,266,880 49% 3.77MB/s 0:48:33 10,813,264,576 49% 3.77MB/s 0:48:34 rsync: read error: Connection timed out (110) rsync error: error in socket IO (code 10) at io.c(794) [sender=3.1.2] ------------------------
