defcon84
Jun 20, 2018Guide
ReadyDR Error 255
I have a share with 422GB ReadyNAS 314 (v6.9.2) that i want to backup to a ReadyNAS 3312 (v6.9.3).
All goes well for 30 minutes, then i get:
"ReadyDR job failure: Unknown error 255 [Backup to NS5...
- Jun 26, 2018
Hi defcon84,
The 'Broken pipe' status indicates a network issue. Are both NAS devices connected on the same LAN? Are they connected to a switch or are they connected directly to the router?
defcon84
Jun 22, 2018Guide
I cant send the logs of one NAS because it times out..
I'll send the other one now.
The nic isn't disabled, because i can still access the web gui and ssh connection isnt reset.
JohnCM_S
Jun 26, 2018NETGEAR Employee Retired
Hi defcon84,
- defcon84Jun 27, 2018Guide
It goes over a site-to-site VPN connection that seems to be dropping indeed.
Thanks for the help!
