sfckor
Mar 02, 2012Aspirant
ReadyNAS 1000s No Frontview after 4.1.8 FW upgrade
I just recently received this from someone else in IT, I wanted to set it up to do backups. I installed the 4.1.8 FW update and have completely lost all Frontview. It sees it on Raidar, did an OS rein...
Thomas_xh1
Mar 06, 2012Tutor
It is too old firmware of 2.00cp1, now it is better to reboot this unit to "tech support" mode, and let me check whether the data is OK.
If yes, I suggest you backup all your data and run factory default with 4.1.8, then restore it.
