LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
LaszloFolgerts
:D I 've got it working!! :D
I had a hunch about adding a gigabit switch, so I went and got one.
I didn't get it to work right away, so I removed the 7.7.3 version of LMS and uploaded 7.8.0. I had to do that twice, actually, because the LMS deb file wouldn't confirm being uploaded.
After that I turned LMS on and launched the app. Then I went to my squeezebox to setting>advanced>networking>ethernet
First it will tell you it isn't able to connect because it can't find a DHCP. You then have the option of adding the IP of your ReadyNAS manually. You're also being asked for a subnet mask, gateway IP adress and a DNS but you can just hit "done" each time because those values are already inserted. After that it confirmed being connected to ethernet.
Then I went to "My music" from the main menu and I could access my files right away! I'm so happy!! :D
Thanks everyone for the replies and special thanks for Pussin for developing the LMS app!!!
