LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
LaszloFolgerts
Aug 26, 2014Aspirant
@vandermerwe: thanks for the reply. Here are my settings:
Ip adress: 192.168.137.179
Subnet mask: 255.255.255.0
Gateway IP adress: 192.168.137.1
DNS: 192.168.137.1 (same as above)
It also happens when I switch back from wifi, for instance when I wanted to listen to internet radio. If I then want to switch back to ethernet, it won't connect by itself and I have to enter all those values again.
Switching to wifi is no problem though, those settings apparently are stored on the SB.
thanks in advance
thanks in advance
