LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
LaszloFolgerts
Aug 27, 2014Aspirant
sorry for the late reply but I'm not quite sure what you mean. The settings above are used to log onto the ethernet network, i.e. to connect with the RN102
Those are the same settings I have to enter everytime I want to switch from wifi to ethernet. One would think there should be a way to store those settings, just like with the wifi...
Could you tell me where I can find the settings you are referring to?
thanks in advance
thanks in advance
