LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
Aug 27, 2014Guru - Experienced User
No, that's not what they are. The subnet mask, gateway address, and DNS server are configuration settings for your network, and not part of a log on. Normally you would not be entering them along with the RN102's local IP address. Instead you'd be entering the local IP address of the squeezebox - which should be a different address from the wifi IP address.
LaszloFolgerts wrote: The settings above are used to log onto the ethernet network...
When you say "switch from wifi to ethernet", are you meaning that the squeeze has both, and both are always connected? Or are you saying something else?
Also, are the subnet mask, gateway, and DNS server the same for the wifi network?
I don't own a squeezebox touch, but something is a bit muddled here. Do you have a link to the squeezebox manual?
