LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
LaszloFolgerts
Aug 27, 2014Aspirant
My Squeezebox has both wifi and ethernet capabilities. It can connect with either one but not both at the same time.
I use wifi for internet radio and I use ethernet to connect with my RN102 running LMS 7.8.0 to access my music.
You were right about the IP-adress! It's the one of the Squeezebox, not the RN102 (I don't know why I thought that, maybe because one has an 9 at the end and the another a 6 an I mixed them up)
I have the Sqeezebox connected to the RN102 through a TP-Link TL-GS105 5-port gigabit switch. Should I have gotten a router instead?
I looked into the manual but it directs me to the support page but I can't find much info about my particular set-up
I'm not quite sure if my RN102 has a static IP-adress. Is there a way to check and/or change that in the GUI or otherwise? I'm in System>settings on the GUI but can't find anything that points to that direction.
Thanks in advance,
Laszlo
Thanks in advance,
Laszlo
