LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
vandermerwe
Aug 27, 2014Master
Ok so you understand now. I have Squeezeboxes and I've tested switching between wifi and ethernet access. Each time you change you will need to go through the network settings, although they will have been retained from your previous setup.
There isn't a way to just select ethernet and go straight to music if you have been on wifi and vice versa.
