LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
vandermerwe
Aug 29, 2014Master
I have asked you this before, but are you absolutely certain that when you enter the ethernet setup on the squeezebox, that you are selecting a static setting and entering the IP address that you want the squeezebox to use on YOUR LAN, not your neighbour's?
The other thing you can try is to setup a static wifi IP address for the squeezebox that is the same as your ethernet IP address ( the squeezebox IP address).
