LaszloFolgerts
Aug 25, 2014Aspirant
ReadyNAS 102 Squeezebox Touch connection issue
Hi all, new here so please be nice :D Ok so I've bought myself a Squuezebox Touch and a ReadyNAS 102 in which I installed 2 WD RED 3TB disks. The goal is to be able to stream all my music files...
Sep 13, 2014Guru - Experienced User
If you do want to assign any static addresses, of course you need to coordinate with your neighbors. If their router supports address reservation that is a better way to go.
If the issue is that the wifi connection to the neighbors isn't stable, then (as I posted on the other thread) the best solution might be to install your own router between the extender and your equipment. Then your local network will be stable, though your internet service might not be.
