wdunn
Jul 29, 2017Aspirant
ReadyNas 102 WD Red 8TB
I have been using 2 WD Red 3TB drives with no issues in my ReadyNAS 102. Time to upgrade. I purchaced 2 WD easystore 8TB desktop drives, which come with a WD Red 8TB drive. Prior to removing the dr...
- Aug 07, 2017
StephenB wrote:I never ran 2x8TB in my RN102, but I did successfully run 8 TB + 6 TB jbod for several months (WD80EFZX+WD60EFRX)
SOLVED:
The 2 WD 8TB Red drives were preformatted. There is fine print that states the NAS will not start if the drives are preformatted. The solution was to do a Factory Default boot with only one drive installed. Once that's reformatted, then add the second drive and sync them up (Raid-1). Sync time was about 24 hours.
Jul 30, 2017Guru - Experienced User
- wdunnAug 07, 2017Aspirant
SOLVED:
