Telfon
May 07, 2016Follower
ReadyNAS 102 will not update to 6.4.2
I cannot get my ReadyNAS 102 to update from 6.4.0 to 6.4.2. I go through the update procedure, it says it is updating, reboots, and it is right back on 6.4.0. I have uploaded the firmware manually ...
mdgm-ntgr
Jul 20, 2016NETGEAR Employee Retired
ElMassivoG if you look under System > Logs does it show that the complete_flash_update package failed to install or that it installed successfully?
That app will download the firmware from the internet and then update the firmware on the flash of the unit. This can take some time especially if you have a slow internet connection.
I have sent you a PM.
ElMassivoG
Jul 22, 2016Aspirant
Hi Brian
I thought I had replied but cannot see it here. Firstly thanks for your interest. I have tried many times and all I get is failed to install. I had a brainwave and tried copy to flash drive and doing Apps/Upload from there. That failed too. That file is only 20 something kb. Is that right? I have very good broadband. If I could get the thing to upload the flash file it would be quick. The other strange thing is that my system doesn't detect new firmware when I use Settings/Check for Updates. I get the little spinny disc then nothing.
G
