buddyrjm
May 02, 2016Aspirant
ReadyNas 104 not expanding after drive install
I have a ReadyNAS 104 with 3 x 3TB drives installed in X-Raid and it shows raid 5 with 6 TB storage which is fine. I added a 4th 3 TB drive (same model as the first 3). The ReadyNAS 104 made the driv...
BrianL2
May 03, 2016NETGEAR Employee Retired
Hi buddyrjm,
Could you send us a complete copy of your device logs? Instructions are available here.
Kind regards,
BrianL
NETGEAR Community Team
- buddyrjmMay 03, 2016Aspirant
Logs have been emailed. Please let me know what you find.
- mdgm-ntgrMay 03, 2016NETGEAR Employee Retired
Thanks for the logs. I have removed the email address from your post.
The logs show that a resync is taking place. At the time you downloaded the logs it estimated there were 6429.1 minutes to go. Once the resync completes the volume should then expand.
Once your volume has expanded you may then wish to run a balance.
