MellyMem
Feb 10, 2018Aspirant
ReadyNAS 104 out of memory 300 firmware 6.9.2
hi everyone i have a readynas 104 - software ver is 6.9.2 - hdd 4 x 2tb drives. I had a power cut 3 nights ago and ever since that night my nasbox activity light is flashing like a **bleep**. ...
- Feb 14, 2018
Hi
System Fixed!
Firstly to mdgm THANKS for your time in trying to help me i really appreciate it..:)
It seems that the snapshots were the cause of the "out of memory error" I didn't realise that the system was taking snapshots everyday and keeping them for upto 3 years, the oldest one was dated 2014.
I have a backup of my data and could have done a factory reset but i wanted to try and fix this first.
The fix:
Due to the power cut this forced the system to do a rescan and coz of there being loads of snapshots the system run out of memory. I managed to delete some before the system hung again and noticed that as there were less snapshots the system was running for longer, so i kept rebooting and deleteing snapshots until i got the system to a state where i could delete almost all of them. After reboot the system started to behave and I went through and disabled all snapshots from my shares. However there were some snapshots that seemed to be orphaned and i could not delete them but the system was now stable but running very slow. So i did a OS Reinstall from the boot menu as suggested by mdgm and now the system appears to be stable , runnuing a proper speeds AND i was able to delete all the remaining snapshots which gave me back 1TB of disk space!! I have done 5 reboots as a test and everything is running normal ,phew!! I have turned off all snapshots, quotas and bitrot protection and hopefully it won't happen again.
I hope this helps someone who is having similar trouble.
FYI to everyone:
MAKE SURE YOU HAVE A BACKUP OF YOUR DATA INCASE YOU HAVE TO DO A FACTORY RESET! I WAS LUCKY!!!!
Thanks again to a great supportive community and remember,
"Together we are Dynamite!"
grats
Melly Mem
